Cheers Billage and Jezza! The tooth... She Grows longer. :(
Fellow Cancerian.
Is it now? If so, enjoi it.
:thanks: mate
I feel I should Quote the above as perhaps the subtlety was lost on the day...
Twas Richard's on the 1st.
Did you go to Woolies, buy a birthday cake, make sure you see the chick (who loves 'Lines) ... make sure she sees the birthday cake and say to her .. yes it's my birthday :dry: ... just getting this cake take it home in my Skyline to have a little party ... oh yeah, on my own :( !!
Have bottle of this ---> http://www.thewinesociety.com.au/wines/27343/climbing-cabernet-sauvignon-2011
Left over from Mum n Dad's Anniversary. (they grew up and met in Orange) so it was fitting we got wines from there. ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
