Oh yes, very much so. fortnightly wash and interior clean etc :) keen as all hell to take it down the Clyde next weekend...f**k, the while drive to Narooma will be sick haha
Fingers crossed for decent weather.
Nice Troy! Enjoy it. Lookout for Roos between Bungendore and Braidwood.
and just in General. :P
