Has anyone got a Caliper windback tool?
Farken rear brakes on the daily screw back into place not push and i can't get them to budge. Want to use the proper tool before i buy all new calipers :\
No. Just be sure to catch the gasket(s) or they fall into the abyss. Be sure to use a rag or something to cover the turbo outlets to ensure nothing falls into them.
Awesome! Thanks mate. Taking it off for polishing along with my Apexi intake pipes.
What car and what does the piston look like? I made one for the 31 rears and it worked very well. :)
Shitty Alpha 156.
$T2eC16JHJF8FFqJjjt!pBSDMKNwhE!~~60_35.J
Am going into Ultimate tunes tomorrow with the calipers and if we can't get the fkers to move im just going to buy new calipers.
Depending on materials / tools available and willingness to have a crack, shouldn't be too hard to make something to fit that.
Metal pipe, hacksaw, drill and some kind of handle / leverage springs to mind. :)
Ill just yell at it. That will hopefully sort it.
Really not in the mood to spend $300 on the daily. Thats $300 i cant spend on the GTR
We have learnt many things today, Anthony has caliper issues on his daily, Rob has an idea if not a solution for most things mechanical (comes with artwork) ... and most importantly we have learnt that Troy reads the SAU/ACT Thread in the cr@pper!! (oh, and apparently he doesn't have a tool!)
And they say you learn nothing in car forums!!
Edited by THE34T
Yeah good and bad. Still having boost issues, need a bigger wastegate so its staying in the shed till i do that.
Will be out ultimates way later Kyle. might see you there... :ph34r:
GTR needs to go back in but Adrian is being lazy. Will have to wait till after i go overseas now =(
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
