The food section has been the same price since it opened back in 19xx. Costco is pretty cool, did you see the $80,000 necklace (or earrings? cannot remember) just sitting in the class cabinet? haha
Hello Peeps,
Just dropping in because I have to finally pull my finger out and take my 34 to a tire place to get these locknuts off. (never managed to get a key or socket to work)
I'm going to organise a day permit so that I can drive it to a tire place but I need some recommendations on where to take it for something like that.
Northside gungahlin area if possible.
Yes, us Belconians will say yes, Bob Jane is good.
They may brush some sloppy tyre dressing on, which they do too much. Then it sprays up the side of your car.
That is their only fault i know of.
I just ask for no tyre dressing.
Haha I been doing the opposite and just saving all my kesh for the flex tune.
Decided to finally pull my finger out and get this shit sorted before rego comes up for the 33 again.
Just called Belco and they booked me in for tomorrow, they said it should only cost about $45 and another $25 for fresh locknuts
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
