The food section has been the same price since it opened back in 19xx. Costco is pretty cool, did you see the $80,000 necklace (or earrings? cannot remember) just sitting in the class cabinet? haha
Hello Peeps,
Just dropping in because I have to finally pull my finger out and take my 34 to a tire place to get these locknuts off. (never managed to get a key or socket to work)
I'm going to organise a day permit so that I can drive it to a tire place but I need some recommendations on where to take it for something like that.
Northside gungahlin area if possible.
Yes, us Belconians will say yes, Bob Jane is good.
They may brush some sloppy tyre dressing on, which they do too much. Then it sprays up the side of your car.
That is their only fault i know of.
I just ask for no tyre dressing.
Haha I been doing the opposite and just saving all my kesh for the flex tune.
Decided to finally pull my finger out and get this shit sorted before rego comes up for the 33 again.
Just called Belco and they booked me in for tomorrow, they said it should only cost about $45 and another $25 for fresh locknuts
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
