Keen.
So... what time? 10 ish?
Ill most likely head home early too.
Fixed my brakes, it was a little bit of metal riveted to the pad, bent over to act as a pad wear alarm.
Theres enough pad thickness on there for now, but i will change it soon. I have a full set of pads waiting to go on.
How long are they out at the track for? If we aim to leave at 9 is that too early for late sleepers? And just plan to meet 15-20mins earlier then whatever time we choose to leave.
Edit: just saw miks post. 10am also works for me.
Edited by dontyellpl0x
Hey #GTRKat is your toy on E85 yet?
Nope. Making 560kw on 98.
Anyone want to come to wakefield on Saturday to see a few of the NSW peeps?
34GeeeTeeeteee is going to be there with his beast :D
Bugger, I would have gone to this but in Brissie for the weekend.
Couldnt find you guys to say "see yous later"
Saw a 4x4 and caravan on its side on the highway, just missed seeing it go over by a second or two :O apart from that it was a good day. A few Skylines there today.
Spoke to the guys that own the blue 32 GTR, nice and simple fun car to drive, makes me feel a lot better about mine, they are old cars.
That white 34 is very fast. Wow. :yes:
Missed the rain on the way home, a little bit of wet road was all.
Edited by D.I.Y. Mik
Yep, Great day Buoys. :cheers:
Got some cleanish pics but then a mysterious hair crept in to ruin them. :verymad:
These Guys and Myself.
We went here.
Saw this Guy.
and some of these.
post-78856-0-30538400-1414824439_thumb.jpg post-78856-0-75319000-1414824473_thumb.jpg post-78856-0-39325700-1414824505_thumb.jpg post-78856-0-63997500-1414824533_thumb.jpg post-78856-0-44663500-1414824562_thumb.jpg post-78856-0-93926000-1414824591_thumb.jpg post-78856-0-70636600-1414824628_thumb.jpg post-78856-0-65210000-1414827118_thumb.jpg
Lost Mik and then we did this.
post-78856-0-58462900-1414828741_thumb.jpg post-78856-0-38613200-1414828764_thumb.jpg post-78856-0-75468700-1414828788_thumb.jpg post-78856-0-38926200-1414828826_thumb.jpg post-78856-0-07157200-1414829431_thumb.jpg post-78856-0-48578600-1414828725_thumb.jpg
Unfortunately I didn't get any of the Massive Flames out of Chris's Zaust. :O
:woot:
Hey all,
Had my Twin Turbo and Apexi intake pipes polished. I installed them today.
Also have Richard's old polished plenum which has been re-polished. Thinking of trying to install it myself.
Had it done locally by OTF Detailing. His name is Dan, number is 0449049030.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
