Keen.
So... what time? 10 ish?
Ill most likely head home early too.
Fixed my brakes, it was a little bit of metal riveted to the pad, bent over to act as a pad wear alarm.
Theres enough pad thickness on there for now, but i will change it soon. I have a full set of pads waiting to go on.
How long are they out at the track for? If we aim to leave at 9 is that too early for late sleepers? And just plan to meet 15-20mins earlier then whatever time we choose to leave.
Edit: just saw miks post. 10am also works for me.
Edited by dontyellpl0x
Hey #GTRKat is your toy on E85 yet?
Nope. Making 560kw on 98.
Anyone want to come to wakefield on Saturday to see a few of the NSW peeps?
34GeeeTeeeteee is going to be there with his beast :D
Bugger, I would have gone to this but in Brissie for the weekend.
Couldnt find you guys to say "see yous later"
Saw a 4x4 and caravan on its side on the highway, just missed seeing it go over by a second or two :O apart from that it was a good day. A few Skylines there today.
Spoke to the guys that own the blue 32 GTR, nice and simple fun car to drive, makes me feel a lot better about mine, they are old cars.
That white 34 is very fast. Wow. :yes:
Missed the rain on the way home, a little bit of wet road was all.
Edited by D.I.Y. Mik
Yep, Great day Buoys. :cheers:
Got some cleanish pics but then a mysterious hair crept in to ruin them. :verymad:
These Guys and Myself.
We went here.
Saw this Guy.
and some of these.
post-78856-0-30538400-1414824439_thumb.jpg post-78856-0-75319000-1414824473_thumb.jpg post-78856-0-39325700-1414824505_thumb.jpg post-78856-0-63997500-1414824533_thumb.jpg post-78856-0-44663500-1414824562_thumb.jpg post-78856-0-93926000-1414824591_thumb.jpg post-78856-0-70636600-1414824628_thumb.jpg post-78856-0-65210000-1414827118_thumb.jpg
Lost Mik and then we did this.
post-78856-0-58462900-1414828741_thumb.jpg post-78856-0-38613200-1414828764_thumb.jpg post-78856-0-75468700-1414828788_thumb.jpg post-78856-0-38926200-1414828826_thumb.jpg post-78856-0-07157200-1414829431_thumb.jpg post-78856-0-48578600-1414828725_thumb.jpg
Unfortunately I didn't get any of the Massive Flames out of Chris's Zaust. :O
:woot:
Hey all,
Had my Twin Turbo and Apexi intake pipes polished. I installed them today.
Also have Richard's old polished plenum which has been re-polished. Thinking of trying to install it myself.
Had it done locally by OTF Detailing. His name is Dan, number is 0449049030.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
