This made me laugh (twice)
how lucky can you be http://www.9news.com.au/world/2015/01/03/11/50/rocket-hits-family-watching-fireworks-from-balcony
and this one http://www.9news.com.au/national/2015/01/02/16/06/nsw-cyclists-dramatic-roadside-stack
yes I'm one of those people that dislike and or despise mamil cyclists
Edited by Sinista32
Cos i cant go 3 years without losing a point for something, so eventually i run out.
If you can, they reset your points.
Just wanted to clarify this one - you don't need to go the full 3 years without losing any points in order to get them back. Demerit points are applied (or deducted, technically) on the date of the infringement, and then 3 years after this date those points are returns to you. So as long as you don't accrue a TOTAL of 12 points (or 4, whatever licence you hold) in any 3 year period, you're fine.
So if I lose 6 points today, then another 2 points in June, I will have 4 points remaining until 14/01/2018 (assuming I don't lose any more between June and then). Comes 14/01/2018, I will have those 6 demerit points returned to my licence, leaving me with 10 points until June 2018, at which point the remaining 2 will be returned also.
I'm sure everyone knows this already, but I just thought I'd clarify a bit more :P
No, your wrong.
I wish it was like you say, but it isnt.
Source, please? I've been advised by multiple RTA employees on more than one occasion, and have clarified it with them to be sure.
It most certainly ISN'T "3 years with NO loss of points", which is what you're suggesting.
For ACT:
http://www.rego.act.gov.au/infringements/demerit-points
12 or more points within a 3 year period.
Technically I was wrong in that you don't start with 12 points to lose, but you start with 0 and accumulate them until you reach 12 within ant given 3 year period. My explanation above is still correct for the purpose of this discussion.
Well if you incurred LESS than 12 points within the 3 year period beginning from the date of the first offence, then yes. You have been treated unfairly. Unless your loss of licence wasn't directly due to accruing 12 points within 3 years, and was the ruling of someone with the power to revoke it.
End of the line is that as of whatever date the information in the link above was published, I'm correct (with regards to ACT licencing at least).
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
