This made me laugh (twice)
how lucky can you be http://www.9news.com.au/world/2015/01/03/11/50/rocket-hits-family-watching-fireworks-from-balcony
and this one http://www.9news.com.au/national/2015/01/02/16/06/nsw-cyclists-dramatic-roadside-stack
yes I'm one of those people that dislike and or despise mamil cyclists
Edited by Sinista32
Cos i cant go 3 years without losing a point for something, so eventually i run out.
If you can, they reset your points.
Just wanted to clarify this one - you don't need to go the full 3 years without losing any points in order to get them back. Demerit points are applied (or deducted, technically) on the date of the infringement, and then 3 years after this date those points are returns to you. So as long as you don't accrue a TOTAL of 12 points (or 4, whatever licence you hold) in any 3 year period, you're fine.
So if I lose 6 points today, then another 2 points in June, I will have 4 points remaining until 14/01/2018 (assuming I don't lose any more between June and then). Comes 14/01/2018, I will have those 6 demerit points returned to my licence, leaving me with 10 points until June 2018, at which point the remaining 2 will be returned also.
I'm sure everyone knows this already, but I just thought I'd clarify a bit more :P
No, your wrong.
I wish it was like you say, but it isnt.
Source, please? I've been advised by multiple RTA employees on more than one occasion, and have clarified it with them to be sure.
It most certainly ISN'T "3 years with NO loss of points", which is what you're suggesting.
For ACT:
http://www.rego.act.gov.au/infringements/demerit-points
12 or more points within a 3 year period.
Technically I was wrong in that you don't start with 12 points to lose, but you start with 0 and accumulate them until you reach 12 within ant given 3 year period. My explanation above is still correct for the purpose of this discussion.
Well if you incurred LESS than 12 points within the 3 year period beginning from the date of the first offence, then yes. You have been treated unfairly. Unless your loss of licence wasn't directly due to accruing 12 points within 3 years, and was the ruling of someone with the power to revoke it.
End of the line is that as of whatever date the information in the link above was published, I'm correct (with regards to ACT licencing at least).
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
