This made me laugh (twice)
how lucky can you be http://www.9news.com.au/world/2015/01/03/11/50/rocket-hits-family-watching-fireworks-from-balcony
and this one http://www.9news.com.au/national/2015/01/02/16/06/nsw-cyclists-dramatic-roadside-stack
yes I'm one of those people that dislike and or despise mamil cyclists
Edited by Sinista32
Cos i cant go 3 years without losing a point for something, so eventually i run out.
If you can, they reset your points.
Just wanted to clarify this one - you don't need to go the full 3 years without losing any points in order to get them back. Demerit points are applied (or deducted, technically) on the date of the infringement, and then 3 years after this date those points are returns to you. So as long as you don't accrue a TOTAL of 12 points (or 4, whatever licence you hold) in any 3 year period, you're fine.
So if I lose 6 points today, then another 2 points in June, I will have 4 points remaining until 14/01/2018 (assuming I don't lose any more between June and then). Comes 14/01/2018, I will have those 6 demerit points returned to my licence, leaving me with 10 points until June 2018, at which point the remaining 2 will be returned also.
I'm sure everyone knows this already, but I just thought I'd clarify a bit more :P
No, your wrong.
I wish it was like you say, but it isnt.
Source, please? I've been advised by multiple RTA employees on more than one occasion, and have clarified it with them to be sure.
It most certainly ISN'T "3 years with NO loss of points", which is what you're suggesting.
For ACT:
http://www.rego.act.gov.au/infringements/demerit-points
12 or more points within a 3 year period.
Technically I was wrong in that you don't start with 12 points to lose, but you start with 0 and accumulate them until you reach 12 within ant given 3 year period. My explanation above is still correct for the purpose of this discussion.
Well if you incurred LESS than 12 points within the 3 year period beginning from the date of the first offence, then yes. You have been treated unfairly. Unless your loss of licence wasn't directly due to accruing 12 points within 3 years, and was the ruling of someone with the power to revoke it.
End of the line is that as of whatever date the information in the link above was published, I'm correct (with regards to ACT licencing at least).
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
