Haha that's hilarious!
Are you taking your own car to the track day? My 33 runs out of rego this Tuesday so I won't be taking it, but I'll keep an eye out for your car :thumbsup:
Edited by dontyellpl0x
Hmmm... Start it up and jiggle every electrical connection under the bonnet and see if you can get it to happen again.
AFMs, Ignitor, CAS, O2, Coolant Sensor, injectors etc... If nothing then check Fuel system. ie. Pump is ok? Electrical Plug, Filter, Got Petrol in tank?
Just food for thought Eric to start with.
When I put a Bosch 044 in the 33 I earthed out the pump wires so the pump always ran at full capacity rather than dropping to low speed at idle etc.
It Definitely ran stronger.
If you still have the Factory pump in there, maybe it's time for an Upgrade. :yes:
Just a question to those that have had an unregistered vehicle permit for a day before. It says on the rego.act website that you may need an inspection report of the vehicle if applicable.
Has anyone actually ever needed an inspection report before?
Cheers
Never needed one for the UVP. Had to get one when I first brought the car in from Japan in both SA and ACT jurisdictions. It's usually just a piece of paper from over the counter. I was told though that the UVP was only good for driving the car within ACT so had to run the gauntlet briefly to get it over to ESP which was only a few 100 metres outside of the border.
Hope this helps.
Thanks Chris.
Yeah I did notice that it is for ACT only but then also noticed on RMS it says "NSW recognises permits issued in all other jurisdictions provided the vehicle is operated in accordance with the conditions of the home jurisdiction."
But then I suppose to the ACT UVP conditions are that its for the ACT only anyway, so catch 22.
My car runs out of rego on the 20th and because I'm between jobs at the moment I don't want to pay for rego when I've already got my daily rego'd. We've got this track day on the 24th :( I'm thinking I may just go halvsies and hire a car with another guy again.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
