TBA.
The exhaust is going to be a restriction still but we've finished the fuel system off and I finally went to the Haltech from the Autronic so I have flex fuel!
I put a Motec logging dash in too, so now we can fine tune everything a lot better.
I'm expecting over 600 but we'll see.
Car/combo with the right exhaust will make over 700.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
