A bit too exy for you at the moment mate
R34 Getrag Gearbox
Transfer case
Nismo Twin Plate
Shafts Front/Rear
Cross member
Engine mounts
Shift Knob
Conversion kit parts
Nothing wrong with my 5speed so in no big rush
It over captilises my GTR. Meaning wont get money back once fitted but will very nice to drive :D
I wondered if you were still doing this. Will be very nice once its done mate!!
The red 4 door is a mate/customer of mine. Goes pretty well for a barge haha.
Am going to try make gtr fest even if i cant take mine.
Whens the all jap day? Im not on the facebooks and i cant find a date?
ACT All Japanese Car and Bike Show
Hey Everyone,
We are putting on the All Japanese Car and Bike show again this year after last years sucess. Event details as follows:
Cost: $10 per car/bike, gold coin for spectators
Date: Sunday 10th April 2016
Time: Entrants - 8.30am to 10.30am, Spectators from 10am. Event close at 2pm.
Where: Thoroughbred Park, Randwick Rd, Lyneham ACT
The show is open to all cars and bikes made in Japan, plus those Australian made cars that are the same as a Japan-made model (e.g. R31, Gemini) Note: an exception is granted for Holden badged Geminis and Australian built skylines because the clubs that represent those vehicles do not differentiate. More exceptions may be made at the organisers discretion.
The venue requires that you place a drip tray under your car (a flattened out cardboard box will do). If you don't have one, you won't be able to be part of the show. Only certain areas require drip trays, more information and a map to come shortly.
Any anti-social behavior will not be tolerated, i.e burnouts, speeding. You will be removed from the venue and subsequently banned from any future events.
This event is proudly sponsored by, Rotary Enthusiasts of ACT, Meguairs, Liqui-moly, House of Kolor, Shannon's Insurance and Techworkz.
Make sure you note yourself as 'interested' or 'going' so that you can follow the regular updates, as I won't always be able to update each forum.
https://www.facebook.com/events/1302677969748332/
Thanks, hope to see you there!
Would anyone know this silver? Or do you think this is a respray? The darkest silver I can find for a BNR34 is "sparkling silver" paint code WV2. But doesn't really match the paint in the picture or does it? Google images / other GTR forums are not really helping. The only info I got of the shown GTR is that it's a new import for an ACT owner.
Cheers!
So who is in? http://www.sau.com.au/forums/topic/463871-2016-gtr-festival-presented-by-motive-dvd/
I will leave from Maccas on Fed Hwy (Near Exhibition Park) early on the morning if anyone wants to convoy up.
  • Like 1
I just bought some spectator tickets so will maybe see you guys along the way :)
Ill be heading there in the R as it is going in the Heritage display.
provided it's farken fixed by then....
  • Like 1
  • 1 month later...
  • 5 weeks later...
  • 1 month later...
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
