Hey all,
I've just got myself a Blitz LM Intercooler and it comes with a stencil so you can paint blitz on it.
I think I'd rather use the inverse of the stencil and paint the whole thing black for stealth.
Can anyone see any problems with this?
I was just going to get some cheap arse black spray can. Does it flake off the end tanks after a while or what?
Also if anyone has installed one of these on an r34, did you have to cut your front bar?
Thanks.
  • Replies 68
Sounds good, except that I'd used some of the high temp paint. Reason being that the inlet tank is prone to get quite hot and as you said regular spray paint may crack and peel over time. This VHT one is pretty good stuff, I've used it on my exhaust front pipe. Here's a pic of the stuff I'm talking about:
It's good sh1t
The Intercooler will probably work better painted black, the author of the 21st centuary performance book found that his r32 gtr lost a few kilowatts when he stripped the paint off.
How does that work?
I was just about to comment that the layer of paint may actually reduce the cooling properties of the intercooler by acting as a buffer between the air and the cooler elements...
Can anyone comment?
thats what i was thinking also. when i eventually get my front mount i want it black but i dont want to jeopardise cooling performance, well maybe just a little but not too much.
Keep in mind the following :
Black absorbs heat
Silver & White Reflect heat
I reckon you're thinking of heat in sunlight, where black absorbs heat. In darkness (ie within your front bar, it makes no difference, UNLESS the layer of paint inhibits/restricts the cooling action of the air flowing through it. I may be wrong though, please correct me if so......
Radiators are black...
and so is my intercooler now.
I'm glad I asked the paint people though. They said that the high temp paint would peel off after a while so I got some primer for use with aluminium and then put the high temp paint over that. They actually got the distributor on the phone for me to explain it all.
Anyway my cooler now says Bl!tz in cooler colour with black everything else.
Excellent. I think even if the black does absorb heat that is no bad thing as the inside of the cooler is nearly always going to be hotter than ambient temp so if the black paint does absord heat, wouldn't it be helping draw heat out of the cooler? I dunno, but i don't think it'll cause a problem either way.
Richard
There's a trade-off when painting radiators and the like. Generally, the paint is applied for protection. It is usually black, because black radiates heat better. Yes, it also absorbs heat more, but in this case we want to release heat, not trap it.
But - and here's the trade-off - the resins that make up the paint are poor thermal transmitters. So while the black allows the heat to be radiated more efficiently, the paint itself inhibits the flow of heat from the metal surface to the surface of the paint.
Black has a higher absorbtivity and a higher emissivity than all other colours.
This means it absorbs more heat, as well as emitting more, it has nothing to do with being in the sun or whatever.
The black colour will make it emit heat better, just as long as you dont put too much paint on and fill in the gaps in the cooler core.
what about stock gtr intercoolers??  or is that just a factory asthetics thing??
It's most likely for the protection a coat of paint gives to the metals of the intercooler.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
