Dont take this the wrong way Steve, but the forum is here for the exchange of information...if you want to come on here, wave power figures around then say sorry trade secret...then thats using the forum to drum up business.
Which is cool you are trying to earn a living...but again most of us are on here trying to mod our cars reliably and cheaply and to do so need credible info...I cant see how a certain brand of ecu or a certain tuner can defy the law of physics.
CFM to make that power, the A/F you are running (10.5s is pretty rich and even more remarkable at those power levels that they can still achieve such a rich mixture) mean you need a certain sized injector. Somewhere in there you seem to be soing something differently, cudos to you, but if you iant willing to share then perhaps best to let majic1 be the one telling the story.:D
  • Replies 196
Forget dyno figures, forget 1/4 mile times, i want to see sub 1:05sec times at Barbagallo Raceway:)
I cant claim to sub 65s,but i have run 68s on street tires(205/15bridgestone G3),run hillclimbs,drags,motorkhanas on a tune by SST 2 years ago.No its not a RB25.
Wander around the pits at Barbagallo raceway and note the number of yellow SST stickers on cars in most classes.
1. put magic1's car on a dyno dynamics dyno in shoot out mode, post dyno graph
2. Congrats on squeezing 511*hp from the stock injectors
3. I dont understand why everyone is having a whinge!!! Does it really matter to you that much that Steve is claiming this power on stock injectors? Do you really want to push stock injectors or would you rather put larger cc injectors in??
I know that i have forked out $$$ for my engine, i aint gonna be a cheapskate and not go for larger injectors for insurance
4. Steve and SydneyKid need to get it on and be done with... toooooo many sly remarks and personal attacks going on in ALL these threads when these 2 disagree with each other.
*non DD dyno
Damn western australians. Always surrounding themselves in conspiracies and secretcy.
The results are , how would i put it astonishing, to the point of unbelievable, but hey if there are ppls to confirm the results and as long as the customer is happy, then a job welldone. But it is also good etiques to explain the proccess of accomplishments.
dyno chart will be up tommorrw done in shoot out mode 4, stamped and all. Want a vid i got one of those to.
the car is now at the limit of the turbo, and maybe the rods.
fuel lines are stardard
is anyone coming over to perth or have any mates in perth that want to go for a ride?
seat of the pantsometer!
Also will be attending the motorplex on wednesday week, was to be this week but im not racing on my birthday.
Regards
Tristan
nd4spd ran 142mph in street trim that aint low.Rob77 had stock pistons.
As for Sean(lagwagon) he cant afford a nice car so he bags everyone that can .
SST is a workshop and as such will not tell any of our secrets but wiil make the cars avalable to any East coast shop thats in town.Magic1 is driving his car around for work as was on sat.
If others cant match this power then try harder.
Magic1 wanted as close to 500 as pos for PAS so we should be pleased he got what he wanted.
From what i read lagwagon is commenting on the cars you tune and use in your arguments. So you call him cheap?
-rob77 had stock pistons thats why it blew. nar sorry there are may people running stock pistons that make big hp but they dont push the the stock injectors.
i belive magic 1s 414rwhp i saw it run on the dyno dynamics, but i can also see how it can be done. Cams would help a heap because there increasing power with out heat so the sock injectors dont need to have such a good spray pattern to get a cool clean combustion.( Which happens with large fuel reg presure) forged pisstons again are up for a bit more punishment then the stock. An efficent turbo at a bar. and a tune that would sacrifice power down low for more up top will give you a dyno queen car that pulls some nice graphs but embarrassing track time for the power.
i dont mean to take anthing away from the car its nice just set up differnt to the way others like it each to their own, id love to own it. As you said steve he was setting it up for the dyno comp, he wanted 500rwhp and you got it.
just alittle curious abit off topic; seems abit of "Attacking" going on between tuners and tuning houses in perth lately? is it just me.
Also what is everyones problem? I have run my car on 2 dynos in perth both DD and i made within 10rwhp on each other (one was @ sst and the other @ hyperdrive). So why when a wa car makes a nice power on stock injectors its it a lie or fake.
seams alot of people are quick to have a goo but each to his own i guess
edit: im pretty sure pauly engine went bang bang cuz he try to run something around 30 or 40psi hehehehe
Its because theoretically injectors can only flow so many cc's of fuel.
Unless there's some other little tricks that not many ppls have tried such as possible huge arsed fuel lines?
and or making sure the fuel pump receives a consistant full voltage of say 14volts.
Every little bit helps I would imagine.
As you increase fuel pressure you decrease flow because the fuel pump has to work harder to push against the force. In turn it slows down. This is the drop in volume.
So theoretically if you decrease the restriction or increase the fuel line size this will give you a higher flow rate at the same restriction or psi pressure.
A 33 percent increase in the fuel pipe diameter will double the volume flow.
I'm not sure how much of a difference it really makes once it hits the injectors though.
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
