Hey guys,
I've got a question.
Barring all monetary and budgetary restraints, what would be the ultimate turbo for the RB25DET.
Not for ultimate power, as we all know you could just strap a monster to the side of it and make power from 6500 - 8000 rpm.
I'm especially interested in you tuners points of view, STT and SK.
Highest average output, best spooling etc. etc.
Interested to see answers.
BASS OUT
https://www.sau.com.au/forums/topic/55255-the-ultimate-turbo-for-your-rb25det/
  • Replies 85
Bass, just comes down to how much power you want out of your engine... just look for the quickest spooling turbo which can get you the power your after. 3037's will get you nice power but is it worth sacrificing it for better response?? its up to you
Bass Junky, it might help if you were to give an approximate rwkw figure.
I would have thought 250-300 rwkw is enough, as I have not seen anyone with more than this get it down smoothly on a street car (but I may be wrong) IMHO over 300 rwkw is 4 wheel drive territory unless you are into lots of wheel spin and chewing up tyres.
I also realise that the shape of the power curve will allow cars with less power to light up, but a properly tuned (smooth and progressive power curve) motor with this sort of power should be drivable on the street.
Probably a nice low mount GT2540. Good response, minimal lag, and nice and stealthy low mounted. :)
You gotta be kidding, the 2540 is one mismatched comp/exhaust side turbo ever.
Bass
For an example at sandown on that sunday running around 255rwkw with my GT30 0.70 a/r comp 0.87 a/r exh i found that coming onto either the front or back straights at around 60 km/h in 3rd at around 3000rpm i had lag issues till i hit just over 4000rpm and came onto boost. If i took these 2 corners in 2nd instead i found that i would get wheel spin and axle tramp instead. I went for a ride in skylinegeoffs car before that and he could use 3rd coming onto those straights with his 'hydrid' turbo and come on boost straight away, but my car felt alot quicker on the straights.
Do you plan on joining the wang soon or just street driving?
I'm with B-Man.
The 2835ProS is an awesome turbo that is just right for the stocker internals.
Excellent response & average power.
To push upwards of 280rwkw od I would either do cams to lower bring the dynamic comp ratio to a safer limit or slap a thicker head gasket in there which effectively also lowers dynamic comp.
Obviously a set of injectors are on the cards.. But thats nothing a set of second hand GTR injectors + a resistor pack can't solve.
So... I would..
2835ProS
Nice FMIC & Exhaust
GTR injectors & Resistor Pack
Fuel pump
PowerFC
Z32 AFM
See how the power is then look at cams to make the motor a little safer and also increase the average power. :D
What do you guys think of the HKS GT-RS, for track use. Rated at 400ps , the hks GT2835 Pro S is rated at 420ps.
Seen it on nengun as a bolt on kit for the RB25det's
http://www.nengun.com/product_info.php?pro...4b067d1b19ad51a
So theres not much more difference between the gtrs and the 2530..And the 2535 is the turbo to go for for decent response excellent mid and good top end for rb25.
Spewing we will have to wait and see what croat can pull out of his hat.I was allready like this turbo is the one for me.What sort of price can the hks 2530 2535 etc be recoed back up for??
With everything else in order, so you get the most out of the turbo in its efficiency range.. probably 2835 Pro or 30xx series
you should choose the best turbo for your intended/current setup, not the best turbo in general for rb25det
or something like that :)
hey peter that turbs doesnt look too bad!
Ide like to see some info on its actuall performance on rb20/5 sr20 etc
building a RB25DET with a TD06-25G, nice laggy turbo with good topend power, and a misfiring system to keep the turbo spooling while I'm off the throttle. The one that I've bought is a metal sleeve thingamajiggy (can't remember the name) so its not steel bearing or ceramic, and can withstand a lil bit more punishment than a standard turbo.
As a standard swap/upgrade for a R33 RB25DET i'd say get a 2530, but I dunno how they react to RB25DET Neo's.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
