yeah, i'm pretty sure i do have the a pillar.
The engine is in pieces, i.e no CAS, no PS pump, no Aircon, no turbs, no coil packs. no loom. If you want the the rest, Ie, long motor (?head and blockstill attached), with monifolds and, basically whatever is left. I'll givem to you for $200.
The rear rack as in hicas rack?? yeah i stilll have it, but the drivers toe arm is a little off, but you should be able to use your arm.
  • Replies 168
Posted Images
Hey mate I'm after this drivers side, rear cradle bracket and pin.
The rear cradle bracket is circled in Green, and the pin is circled in Red.
The pin itself unbolts out of the chassis of the car.
