Have done the tune for awhile now but forgot to add on this sticky thread. Anyway, here are the mods and dyno sheet:
- Stock ECU
- TrueFlo panel filter (same as K&N)
- X-Force turbo back 3" exhause
- Hybrid copy FMIC
- 500hp fuel pump
- TurboTech bleed valve (from forum)
- SAFC
- Turbo: was told by Matt (Hitman) that it could be a R34 one coz made abit more power than stock R33 turbo with similar mods
with the above mods it made 212rwkw @ about 12 psi
without SAFC and at 9 psi it pushed 179 rwkw
My dyno result
Apexi cyclone filter
Gutted Cat
3" Blitz Mandrel from cat back
Solenoid switch on for 1 run, off for the other
I was told the big dip in torque is the cam change over?
But saying that I used to have terrible missfire problems before I regapped to 0.76mm, maybe I just hid this problem???
Any ideas on what turbo I want to get 460+HP at the flywheel (my cal should be at least 400 HP at the wheels), going to buy that and put it on (my mate needs my turbo ASAP for his RB20DET) then hit the fuel & ECU early next year
220rwhp 93 series 1
Engine management - Stock ECU
Boost ran - stock 5-6psi
Turbo - Stock
Fuel used - bp ultimate
Stock all other internals.
no boost controller
no fmic
3" Exhuast from dump pipe back
Pod Filter
no blow off valve
Hi guys, just came back from a tune at tilbrooks in adelaide by martin.
Tune was done at 16psi....at first we got 240 rwkw at 18psi but i decided to settle for 235rwkw @ 16psi as martin the tuner said r33 conrods and internals will not last too long will too high boost.
Mods are in my signature :)
My car is at chasers at the moment fitting and tuning a few things :(
I'm excited to see what the power output would be when I pick it up later this afternoon!! I would be happy with atleast 200rwkw's for now..
I already have the following:
- K&N Pod Filter
- HKS Intercooler
- Turbosmart Bleed Valve @ 10psi
- Custom 3" front/dump pipe
- Hi-Flow Cat
- 3.5" HKS Super dragger cat-back
I'm having the following installed today -
- Z32 AFM
- Nismo 740cc Injectors
- Bosch 040 Fuel Pump
- Nismo Fuel Pressure Regulator
- Apexi PFC
- Raise boost to 12psi
Will let you all know how it goes..
Got it back last night and I was pretty happy with the cars performance - with the stock turbo I managed 209.4rwkws :)
My dyno result for my R32 with an RB25 series 2 motor.
Engine management: Apexi Power FC
-Boost ran: 15psi
-Fuel used: BP Ultimate (98 octane)
-engine mods:
- Z32 AFM
- Sard 550cc injectors
- Aftermarket fuel pump (not sure what it is, but definately aftermarket)
- HKS Front mount intercooler
- Greddy induction kit
- Trust TD06-20g turbo
- Trust High mount exhaust manifold
- Greddy external wastegate with screamer pipe
- 3" exhaust from turbo back with high flow cat
Got 251.4rwkw's
The tune is not very agressive but that's what I wanted as the motor is internally stock from what I can tell. Also has 2 way LSD and Tein HR coilovers.. mmmmm
Here is the dyno chart:
Any opinions? Please reply in here: http://www.skylinesaustralia.com/forums/in...=8&t=93111&st=0 (help keep this thread clean)
Greg
Just got my car dyno'd the other day, not to sure if this is correct but car pulled 198rwkw on about 9.5psi boost. The motor feels like it runs heaps hot when i pop the bonnet after driving for a litttle bit (compared to my mates) but the tuner said its fine. Gonna take the car back as i heard it pinging today at the top end of 3rd gear
R32 with RB25det s2
Engine management: standard
turbo: standard
Boost ran: 9.5psi
engine mods:
hybrid gt-spec front mount
3" turbo back system
pod filter
Iridium plugs
aftermarket LSD
Anyone got any opinions on why its running so hot
Got my car dyno'd today at Tilbrook auto & dyno just to make sure everything was fine and the other dyno reading was correct. To my suprise it was, they said the motor is a bit of a freak and pulled 191rwkw on 9psi. Tried to run more boost but couldnt as the 3bolt gasket has gone on the turbo and wont hold any more boost. Cars not pinging anymore, must have been some bad fuel. The torque figures on the old dyno chart are calculated in some way, to find the actual value you have to divide by some value im not to sure.
Mine's finally running properly and has been tuned. It only took most of the year.
R32 gtst with RB25DET
PFC
s6 rx7 550cc injectors
Frontmount, pod, pump, yadda
Hks cast manifold, Hks T300s turbo and 38mm hks ex wastegate (plumbed back)
3-3.5inch exhaust (depending which end you look at)
Running optimax
238.8rwkw at 20psi
Hey ppls.
Got my car back fom Race Pace today.
As you can see, we made 250 rwkw ar 14 psi.
wouldn't take any more timing or boost.
it's great to drive.
Power making mods:
GCG high flow
poncams 20 x 9.15 lift
full exhaust and other normal mods.
I also picked my car up today, so I thought I'd share my results :angry:
R33 GTS25t (Standard Internals)
GCG GT3040R (0.82 exhaust housing)
Turbonetics 40mm external wastegate
HKS Exhaust Manifold
Nismo 555cc injectors
Walbro Fuel Pump
Blitz LM FMIC
Greddy Profec B Spec II EBC
Apexi Power FC
Splitfire Ignition Coils
HKS Adj Ex Cam gear
Z32 AFM
Apexi Power Intake
3" turbo back exhaust w/hi flow cat
282.9 kw @ 17psi
I think there's probably still more power to be made, but I really didn't want to push for any more with standard internals. The tune was kept a little rich in the top end to try and keep it safe. Overall, the setup isn't as laggy as I thought it would be (starts making boost around 3500rpm with 17psi by 4400rpm) so you could say i'm very happy with the results - MRC in Castle Hill did a great job :P
I picked mine up from Incar Motorsport Wetherill Park on friday.
Thought I'd share the results:
R33 series 2 GTS25t (Standard Internals)
Garrett GT30R (0.63 exhaust housing) (real gt30r - 6 blade, fluted inlet)
Tial 38mm external wastegate
Stock Manifold, w/ spacer
Nismo 740cc injectors
Walbro Fuel Pump
Sard FPR
Hybrid Monster FMIC
Apexi Power FC
Standard Ignition Coils
Z32 AFM
K&N air filter
3.5" turbo back exhaust w/hi flow cat
274.1 kW @ 16psi
Full boost at 3800rpm.
Initially tuned by Ken @ Incar Motorsports, then finely tuned by Ben @ UAS (he rocks).
(thumbnails are clickable)
16psi - 274.1kW @ the rears
11.5:1 AFR
Carlos from Incar Motorsports did an awesome job on the install.
and here's the new graph overlayed on my old setup (stock turbo, injectors, and AFM)
I'm missing some power below 3800 rpm compared to the stock turbo. But eh... I'm loving the power above this!
edit: forgot to mention that Carlos from Incar Motorsport had everything fabricated and installed in 4 days.
Edited by wilch
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
