Dayz special edition Stagea RS V Four
82150kms, automatic, RB25DET engine, Attessa 4wd
New Oxygen sensor, timing belt & service at 81000km
Got 141.3kw at 4wheels @ 10psi
installed most of the following:
- 3inch JustJap stainless single dump pipe system
- 3inch Catco high flow catalytic converter
- 3inch Dayz edition cat-back exhaust system with quiet muffler
- K&N pod filter in custom enclosure
- R34 GTT intercooler
- Hybrid dual stage Electronic Boost Controller
- Apexi SAFC Super Air Fuel Computer
Now 160kw at 4 wheels @ 12psi
added the following:
- Apexi SITC Super Ignition Timing Computer
- Bosch 040 fuel pump with direct battery feed
- Nismo adjustable fuel pressure regulator
- Nissan Z32 Air Flow Meter
- Apexi 'hybrid' front mount intercooler
Cheers, Brendan
Edited by bwilkeson
I got 174
I have
full exaust
pod CAI
Hybrid front mount
10 psi
stock everything else, just running very rich at the moment getting a PFC soon
I have the dyno sheet, just don't know where it is at the moment
Can I expect 200 or close to once the PFC is tuned?
Edited by mnbvcxz690000
If you up the boost to 12psi and with a pfc then you should get up around the 200 rwkw mark.
I had mine dyno'd Friday morning, i have:
Full exhaust with hi-flow cat
HKS pod filter
FMIC
PFC
12psi
Got 199.1rwkw, something i was fairly pleased with.
here is the dyno sheet.
This was a while ago
R33 gts-t
stock turbo
stock intercooler
11 psi
hks screamer dump pipe of turbo
"bullet" mandrel bent 3" system
hi flow cat
hks ssq blow off valve
apexi pod filter
= 175 kW @ wheels
With so many threads about turbo upgrades for RB25's i thought itd be a good idea to start a thread that shows results only, as the results from various threads are scattered everywhere.  Everyone has there own ideas about what power they want so obviously there isnt ONE perfect turbo upgrade for everyone.
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
The idea of this thread is to be a quick reference to various turbo's performances on RB25's, not to be a discussion thread.
Thanks
(If this has been done already let me know, but didnt come up one in search.)
Ok.
4 door R33
5sp man
14lb boost with sua forum boost controller
3inch dump .
standard from cat back
unifilter ramtube and pod filter.
98 ron vortex
trust fmic
Mines ecu
quick dyno with no cooling blower or strapped down
standard horsepower when I got it was 164rbhp
1995 Skyline GTS-t R33
208.9rwkW
Apexi Power FC
Stock Turbo - 15psi - GFB Bleed Valve
Hybrid GT-Spec Tube and Fin Cooler
Full Exhaust
HKS Air Filter
Fuel - Shell 100% Octane
Stock Internals
just a comparison, visual reference chart
ive taken data from various dyno graphs
its by no means a true accurate representation just more of a visual view
it assumes they were all in 4th gear and in the same mode ie shootout or non shootout and all are even playing field comparisons which they never are
  • Like 1
1995 R33 GTS-t (series 1.5)
206rwkw
Engine management - Apexi Powerfc
Boost ran - 13psi with evc 4
Turbo - Stock
Intercooler - Greddy Vspl fmic
Standard BOV
Full 3 inch exhaust (dump pipe and cat from batmbl)
K&N Pod (left open)
Greddy Ex Cam gear
Fuel used - Synergy 8000
Stock all other internals
I felt it was a good tune considering the heat today. It was a pleasant suprise to see that since i always thought my car was a bit of a dud. Many thanks to Unigroup for the tune and fitting me in on short notice
(in case the picture doesnt show up, heres the rev vs power figures)
3000- 105
3500- 117
4000- 134
4500- 154
5000- 169
5500- 182
6000- 200
6500- 206
7000- 204
OK, after recent Dyno day where the car got 129.7rwkw (yes this is not a misprint, due to AFR's richer than 10:1 due to the standard computer) I went to MM for a tune...
159.9rwkw
Management: Power FC
Boost 10psi with GFB atomic boost controller
AFR: 11.8:1
Exhaust: Bellmouth dump, custom mandrel 3" and stainless 3" cat, with 5 Zigen rear muffler (rather large and thus nice and quiet)
Engine: Rebuilt with Venolia Pistons and Chrome Moly rings (that is one is Chrome coated the other compression ring is molydeneum(sp) coated...and for anyone that reads this there is NO SUCH THING AS CHROME MOLY RINGS...
Head: Mild port and polish, reseated valves all standard, standard static compression (8.9:1 on average compared to stock of 9:1)
Malpassi Rising Rate Reg
Walbro Fuel Pump
GFB Stealth Bov
K&N Filter with no heat partition (has been put in since)
Stock Cooler
Stock Turbo
Was a reliable safe tune due mainly stock intercooler and considering this is often driven daily.
The midrange and low down is now incredible. For those about to spray I got more power for same mods. Excellent for you, but this will run this all day everyday!!!
First Dyno Graph Shows before and after with AFR's and the Second is with Boost.
Edited by Bobjones
Stock 1995 R33 GTS-t
173 rwkw
Engine management - Stock ECU
Boost ran - Stock
Turbo - Stock
Intercooler - Stock
Standard BOV
Fuel used - Optimax
Transmission - Manual
Mods
Exhaust - Trust PE2 cat back (stock front/dump pipe and cat)
Air Filter - A'pexi panel (in standard air box)
r33 gts-t, t-57 stage6 ITS turbo high mounted, sard injectors, tomei fuel pump, intercooler etc. nine pack clutch etc.
these are the figures i took from my dyno sheet as i couldnt scan it, does it seem laggy? car is only standard internals so timing is retarded and you can see the difference in power it made when timing was increased from 13 to 15...
at drags i did only 13.8@175km/h with 347atw and 14.2 with 372atw due to no traction and i think clutch is not handling the power (9 pack extreeme clutch 2500lbs pressure plate) as at drags after a run or a little burnout it just doesnt wanna go in 3rd and 4th gear so ill prolly need twin plate especially after rebuild and more power...which twin plates are drivable and reasonably priced?
15-16 psi boost 347hpatw 13 timing
2770rpm 78rwhp (58rwkw)
2950 88 (66)
3400 125 (93)
3850 187 (140)
4300 215 (160)
4750 260 (194)
5200 292 (218)
5650 312 (233)
6100 333 (248)
6380peak 340 (254)
6550 347max (259)
7000 342(255)
15-16 psi boost 372.5hpatw 15 timing
2770rpm 79rwhp (59rwkw)
2950 87 (65)
3400 126 (94)
3850 197 (147)
4300 250 (187)
4750 290 (216)
5200 313 (233)
5650 338 (252)
6100 359 (268)
6380peak 372.5max (278)
6550 368 (275)
7000 363 (271)
Stock ecu, internals, turbo, injectors and pump.
Jasma exhaust (turbo back but no split dump)
Blitz bov
Apexi pod
1st run - stock boost 7psi
2nd run- 10psi via turbotech boost valve and r34gtt intercooler
Well I'm still not entirely happy with things and now my transmission is crapping itself.
Anyway here are the dyno sheets.
Mods.
Stock airbox with Nismo panel filter
GCG highflow turbo
CES split dump/front pipe
3" cat
3" Fujitsubo cat back with 2 mufflers
480cc Nismo injectors
Auto - chipped ECU
R34 GTR fuel pump
R34 GTR regulator
around 12psi boost.
Well my dyno sheet seems to have disappeared from that post but in the meantime my engine blew up and I had to get it rebuilt.
Now has Tomei Poncams Type B 260/260 and reduced compression ratio of 8.75:1. No other changes.
Running 0.9 bar boost I now get 255rwkw
r34 gtt neo 6
[email protected]
td05sh-18g
power fc
trust fmic
hks electronic boost controller
3inch exhaust
walbro fuel pump
trust pod
having some boost problems atm. boost not holding above 12psi. i think it is due to the having no cat and the turbo is over spooling.
R33 GTST series II
HKS GT-RS at 15psi
PowerFC
Nismo 740 injectors
Supra MkIV fuel pump
Pod and full 3" exhaust
229rwkw, and boy was it warm today
Full boost at around 3000
Ben had it up to 240kw, then softened it up a bit.
Drives smooth as silk. Very happy :)
And the figure seems about right - next step up is probably the 2835 pro S which seems to be pulling 260-280rwkw for most
Edited by Beeble
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
