R33 Series 1
Stock internals
Stock injectors
Stock intake manifold
No AFM
911T 500 hp fuel pump
Surge tank
Rising Rate EFI Reg
Haltech E6K
Haltech ignition
High flowed Hitachi turbo (bored compressor housing, 56 mm inducer wheel, ball bearing core, steel wheel with extra trim on the hot side)
Front mount intercooler
Heavy duty clutch
Blitz dual SBC
3.5 inch exhaust
12 psi
247 kw
-Stock ecu
-12 psi
-Bp Ultimate
-Pod, 3 inch turbo back, dump pipe, Otherwise stock
185rwkw in shootout.
The guy found a dead short in the o2 sensor, so it is diabled for now. idle was a joke, so I had to disable the secondary air valve (or whatever it's called) until i get a new one. Fuel economy went from about 12.8L/100k highway cycle at best to 11.6L/100k towing a trailer a 120kph! not bad at all.
dyno attached
Edited by jezzerrr
95' R33, GTS-T, Manual
- 3" Split dump/front & 3.5" HKS Cat Back
- R34 Intercooler
- K&N POD with heat sheild
- Mechanical Boost controller
197.4kw@10 psi at UAS, 11th march 06
196kw@10 psi, AFR=11 at the Hitman, 16th March 06
As per my sig.
Am I reading psi on the right on this chart reaching 25psi :P .
I thought it was 16psi
R33 2.5
Microtech LT12
3" split dump, back
malpassi fuel reg
Walbro pump
Pod
Fmic
Hello from Norway...
RB25DET
Stock block and head, not opened.
Aeromotive fuelpump/regulator,modified rail.
Nismo 740cc injectors, Greddy plenum.
75mm Throttlebody, Electromotive coils.
350x600x100 Intercooler 3"Tubing
Modified HKS manifold, Turbonetics T60*5 old school
HKS W.G., 3"Exhaust, no cat, single muffler.
O.S.Giken twinplate clutch/flyweel.
DTA engine management
353 rwkW/7300rpm(481rwhp)
366 LbFt /5700rpm
21psi peak 4800rpm
18psi @8000 rev.limit
98 ron pumpfuel
Dynapack hub readings
Edited by Tex Willer
Power Fc
3" Straight Through Stainless Exhaust
Sard Fpr
Walbro Fuel Pump
TurboSmart Type 3 Supersonic B.O.V.
10PSI
Standard Turbo
Standard Intercooler
185.4Kws @Wheels
Not Much UAS Tuned Monday
Just Waiting To Get Cam Gears, Intercooler, Plenum And Gt30r To See Wat I Can Get Then Hoping For 240kws Before Having To Change Injectors!
96 Series 2 R33 GTS-T
stock block
stock turbo
stock ecu
stock intercooler
turbotech boost controller @ 8psi (the one that everyone is buzzing about on these forums!)
3" front/split dump, 3" catco hi flow cat, 3.5" cat back
aftermarket air pod
172kw tuned by CRD.
Next is Hybrid GT spec intercooler, and walbro pump (stock pump is lazy). Want to run 12psi after these mods, rekon I could hit 200?
ok i have posted this else where but will put it up here for the sticky.
R33gtst 95
custom FMIC (tube and fin) all pipes are heat repped.
ECU rechiped Nerve Essential stickers all over it.
stock turbo 0.75bar holds boost all the way to 7k
comes on full boost at 2600 but only really makes good power at 5600
hks pod
apexi bleed valve (spikes at .9bar)
apexi catback exhaust (now have split dump, 4" magic cat and splitfire coil packs dyno was before the extra mods)
unknown cams or cam gears
unknown pump
http://home.iprimus.com.au/maddog_wraith/dyno2.JPG
Edited by race_snooze
94 r33 gtst Series 1
Stock Internals,
FMIC Hybrid
Apexi PFC
3.5 inch cat and cat back not turbo back Unknown Cat possibly highflow, but not OEM thats all i know
K&N Pod
Stock Injectors and pump
Splitfire Coil Packs- Best Investment so far of my own
Hybrid Boost Controller, Cheap but effective,
Running Motul 8100
Dyno Tuned in shootout F6 mode, with 95 RON Vortex, forgot to go the Ultimate for tune
178.9 RWKW Tunned to 6-7 psi boost Low boost
High Boost 10 psi, No Readout or tune for this setting,
Tunned at APC Underwood
I would post dyno sheet but no scanner handy
Stock Block and head
Stock injectors
HKS FCON V
HKS VPC
HKS GT3040
HKS 45mm wastegate
HKS Pod filter with No AFM
Tuned length exhaust manifold
Turbo back 3 inch exhause
Greddy Profec B Electronic Boost Controller
ARC FMIC
222kw at the wheels at 0.63bar or 9psi
I was a little stunned at the amount of power for low boost it was running. Ran it twice and got the same results
A set of 550cc injectors would do the car wonders.
Also, car is for sale... just a little plug :P
Auto 4WD Stagea
Only mods:
GCG highflow
3 inch split dump/front pipe BTMBL
5 inch catco cat
3 inch stainless fuji catback
GTR FMIC with custom stainless pipes
Pipercross air filter in stock airbox
~11psi
Coilpacks breaking up 5000+ RPM
Peak power at 6800 and still going 157.7awkw
Will update when new coilpacks, poncams, DFA and SITC
1994 GTS-T S1
Power FC
Tomei Poncams (rest stock internals)
Sard 850cc Injectors
FMIC
Sard FPR
GT3540R .82 EXH on high mount
Turbosmart 48mm progate wastegate
Bosch 044
Z32 AFM
BP Ultimate fuel
full exhaust mods from turbo
Pod filter
15psi boost
410.7rwhp (306rwkw)
96 Series 2 R33 gts-t
stock block
stock turbo
emanage ultimate
blitz intercooler ( not 100% sure)
HKS boost controller
3" cat back
pod
bov
bosch 040 fuel pump
206.9rwkw @.9bar
turbo blown on monday, after new turbo, garrett 307..something or trust t05? any ideas which way to go? mate who sells trust says much better and extra $1000 on top also. Whos running either and has input? Want asap as need car back to drive to work to make the money to spend on the car to get me to work faster
Has someone got a reference dyno sheet of a stock turbo'd engine? That would be good to compare against.
1996 series 2 gts-t
I've got a standard turbo running 1 bar with a power fc that has 290 rwhp
hks intercooler
hks super dragger
malpassi 2:1 regulator
044 fuel pump
96 rb25det
full exhaust - split dump pipe to 3 inch fornt pipe with 3 inch high flow into 3 inch HKS system
apexi pod
hks ssqv
denso 300 l/ph performance fuel pump
sard FPR
hybrid FMIC
apexi avcr (set on .9 to .95 bar)
ngk iridum plugs, synergy 8000 pulp, motul turbo light oil
200rwkw
Edited by ICER33
95 r33 series 1
Standard turbo @ 11psi (turbotech boost controller)
Standard ECU (no piggy back)
Hybrid front mount intercooler
Split dump
3" front pipe
3" X-force cat
3.5" X-force cat back
Pod
New O2 sensor and NGK copper plugs
273.6hp (204rwkw)
Edited by mad082
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
