93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Profect B electric boost controller
ATR43G2.5 .82 rear / .60 comp. 14psi actuator, internally gated.
4inch intake pipe
Adaptronic Plugin
Greedy EBC
Pump 98 fuel. Car maxed 296rwkws on 20psi of boost
E70 Fuel, Car maxed at 350rwkws on 20psi of boost
Also I add this since its forced induction. That is the electric turbocharger that we've been working on in the past couple of month. Its a small gain but a pretty big step forward. The charger made a peak of 2.1psi of instant boost, and a difference of 20HP with 44Nm of torque. It is powered with two small Lipo batteries that weighted 1.5KGs. Red is turbo on and Greent is NA
Video:
96 R33 gtst
3" turbo back exhaust
Pod filter w/ partition and stock snorkel
Blitz return flow FMIC
Nismo 555cc injectors
Nismo intank pump (wired to the battery through a relay)
Nistune z32 ecu
Z32 afm
80mm metal intake
Hypergear Op6 standard high flow turbo on 18psi
Greddy Profec b ebc
Made 248.4rwkw before the car started to ping
r34 neo rb25det with all r33 sensors and intake in an r32
740cc deatchwerks injectors
z32 afm
3" exhaust with 1 muffler and shitty split pulse dump
hybrid intercooler (a real one) with a shitty pod
r32 rb20det ecu with nistune
GCG highflowed rb20det turbo
Added some fuel after these curves which dropped it to about 255kw, peak torque from 3-7k, amazing powerband, incredible to drive, drives like a stock rb25det with 260kw!! Makes 5psi by 1800rpm and 10psi by 2800rpm
afr
http://img135.imageshack.us/img135/959/img20120517221116.jpg
boost
http://img4.imageshack.us/img4/9011/img20120517221202.jpg
torque
Edited by Rolls
R33 GTST
Unopened '96 RB25DET S2
S15 480cc injectors
Z32
Stock intake with inserts
Nismo Pump
Hypergear 21U Highflow
HKS Intercooler
JJR Bell mouth Front Dump
Xforce Cat
Jap Spec 3-3.5" Exhaust
Greedy EBC
PFC
United E85
Blue = 247RWKW @ 14PSI
Green = BP98
  • Like 1
800cc injectors
21U R33 turbo Kai high flow profile using OEM housings. 20psi actuator, internally gated.
3inch intake pipe
Manual boost controller
Peek of 293.8rwkws @ 21psi Pump 98. E85 next week.
Stock head&block
Greddy copy intake mani
Chinee SS exh mani
44mm tial WG
Deatschwerks 550cc inj
splitfires
Profec B2
3" exh
OS giken twin
Pfc
Gtx 3076 .63
95 ron :nuke:
Coolingmist Water/meth 50/50
Low boost 14 creeping to 16 > 323rwhp
High boost 18 creeping to 20 > 378rwhp
r33 1996 s2
stock motor
power fc
walbro intank pump
sard 550cc
plazmaman pro seris cooler
z32 in cooler piping
6boost mani
garrett 3037
pro gate 50mm
asr sump
os twin plate
3 1/2 zorst, no cat
306rwkw on 18 psi
tuned by INDEPENDENT MOTORSPORT
Edited by r33-20s
Nistune RB20 ECU and loom
Greddy MSS for switching VCT
Yellow Jacket Coils
740cc top feed Deatschwerks Injectors
Ally fuel rail
Bosch 044 in tank
Z32 AFM in cooler piping
VH45 Throttle Body
Freddy Inlet Plenum
6boost manifold
Kinugawa (Kando Dynamics) T67 10cm T3 Rear
Tial 44mm MVR Wastegate
Stock RB25 motor
Adjustable exhaust cam gear
Greddy Profec B Spec II
Running my E42.5 (50% BP98 mixed with 50% CSR E85)
Replaced Nistune and Z32 AFM with Vipec and MAP sensor plus added some Tomei Poncams
Edited by SimonR32
R34 RB25Neo, stock ecu, stock turbo
Sstock boost control, boost dropped to 8psi and ran 10:1 mega rich after vct change over about 5,000 rpm.
Walbro 255, front mount cooler, 3" turbo back, aPexi pod and cai.
164kw @ wheels.
Nistune to come. Bleed valve fitted, lsd tightened :)
S2 RB25DET
Power FC
GT3076R
Z32 AFM
E-boost street
3 inch exhaust turbo back
FMIC
Splitfire coilpacks
Warlbro fuel pump
225.2 rwkw on 14psi
243.6 rwkw on 18psi
After having a think Im pretty sure the cat and muffler are restricting power on the 18psi tune.
Tuned by DVS JEZ 0414 879 711
Edited by FordyR31
Had a bit to do with the build of this rb25det of my mates
mahle 86.5 forged pistons and rings
eagle h-beam conrods
sinco manifold
garrett 3076r .82
tial 44mm wastegate
yellow jacket coils
link G4 ecu
sard 700cc injectors
bosch 044 fuel pump
rb26 acl race series bearings
balanced crank
teflon coatd block
greddy 272* 11.5mm lift cams cams and cam gears
greddy 3 layer metal 1.6mm head gasket
ferrea valve springs
brass valve giudes
extensive head porting etc..
Swaping the cams for smaller ones as they dont match the turbo very well,it wants to rev to 10,000rpm but only has a stock oil pump.
256kw 12psi and 286kw 16psi 95 octane fuel on Dyno Dynamics Ramp rate 13
Torque and AFR
http://www.youtube.com/watch?v=KiB2qHt_-EY
http://www.youtube.com/watch?v=pA_47ObEXMk
Edited by NZDRIFTER
series 1 rb25det
ebay t04e turbo
44mm external gate
x-force hi mount mani
spitfire coils
power fc
cometic head gasket
780cc hi-flowed injectors
18psi (wastegate pressure)
270kw/368hp on standard bp premium
everything else is stock
Edited by juzz0
R34 RB25Neo
V-Power 98
16psi
GCG hi flow turbo
Standard internals
3in exhaust + dump
stainless turbo manifold
Apexi front mount Delta type
Z32 air flow meter
Splitfire coils NGK plugs
STD injectors
Walbro fuel pump
Nistune by Toshi
277Kw 500.3FtLb torque
dyno
95 SII R33 RB25DET
modified std plenum forward facing
Z32 AFM
FMIC
740cc injectors
Yellow jacket coil packs
6boost high mount exhaust custom 3" dump with external gate and screamer
GT3076 with .86 rear housing
Power FC
Apexi Profec B spec II boost controller
044 Bosch fuel pump
BP98 pump
0.8 psi boost
386 rwhp
Edited by stR33ter
800cc injectors
Brea bolton manifold.
ATR43SS2 light weight alloy billet comp wheel, .82B rear / .60 comp. 14psi actuator, internally gated.
4inch intake pipe
Adaptronic Plugin
Greedy EBC
E70 fuel 345rwkws @ 19psi bleeding down from 22psi. Fuel pump maxed out.
  • Like 1
wow shes got some torque.... :laugh:
Thats a nice result Stao , wouldnt mind driving that :thumbsup:
Ed*...oops Sorry guys thought I was in the Hypergear thread, but while im here may as well post mine..
Stock motor, manifolds, airbox, cams and cam gear
Adaptronic ..using inbuilt Map and boost control
Kando Td06sl2-20g
44mm tial mvs (1 bar springs)
Xspurt 750 injectors, tomei pump
600x300x76 delta fin FMIC (200$ china job)
3.5 fujitsibo exhaust,
green...United e85 @ 21psi
Blue ...United e85 @17.5psi (final tune)
red...pulp @ 15psi
Little Kando run outta puff on the 25.... but she drives beautifully :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
