Proboost Gtx3582r .82 rear
1200cc
Walbro 460
Stock cams
E85
Cp Pistons and Nitto rods
Plazmaman plenum
415rwkw
Want to go close to 500rwkw but ran out of pump. Looking at adding 2x 044 fuel pumps with the walbro
R34 GTT
Unopened RB25DET Neo 190,000kms
Stock Cams
VCT with Exhaust Cam Gear
Splitfire Coilpacks
Stock Exhaust Manifold
GT30/40 Turbo (Internal Gate)
3.5inch Turbo back Exhaust
No Cat
Stock Plenum
Blitz Return Flow Intercooler
1000cc Injectors
Sard FPR
Walbro 255LPH
Adaptronic Plug-In ECU
98 Octane
17psi: 281.5kw
Made 287kw on a different day for a quick touch up but was not printed.
Tuned thanks to DVS Jez
  • Like 3
Unopened RB25DET Neo with 150,000km
Stock cams
Stock intake and exhaust manifold
3 inch turbo back exhaust
Stock plenum
FMIC
ID 1000 injectors
Walboro 450 LPH pump
Stock FPR
Haltech PS2000 with a MAP and flex fuel tune.
E85 (red trace) and 98 (green trace)
Running 18.5 PSI on E85 and 17PSI on 98
R34 GTT RB25DET NEO unopened engine.
- Adaptronic​ ECU
- 1000CC ID injectors
- Factory cams and cam gears.
- HyperGear ATR45SAT Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
- P98 fuel @ 330rwkws
- E85 fuel @ 365rwkws
- Tuned by Trent Hewitson​, Chequered Tuning​.
  • Like 3
- Adaptronic​ ECU
- Factory cams, cams gears, and all manifolds.
- E85, 380rwkws run out of fuel.
  • Like 1
- NIstune ECU
- HyperGear High flowed factory OP6 Turbocharger
- 3 inches turbo back exhaust
- 3 inches induction pipe with POD filter
- 600x300x81mm Front mount intercooler
- P98 fuel, 292rwkws @ 19psi.
- Tuned by Boosted Brothers
  • Like 1
rb25det
8.5:1 cp forged pistons
spool forged rods
acl bearings
stiffened valve springs
256 poncams
hypergear atr43g3 .82
hybrid intercooler
nismo 740cc injectors
sard fpr
3" exhaust, 100 cell cat, nismo muffler
z32 afm
powerfc
290rwkw at 23psi dropping to 19. Need electronic boost controller to keep boost steady.
  • 3 weeks later...
Garret GTX3076R .82 rear housing
6boost high mount t3
50mm turbosmart pro gate
460lph walbro e85 pump
Haltech Platinum Pro Plug in
Turbosmart eboost street 40psi EBC
1000cc Bosch e85 injectors
Turbosmart fuel pressure reg
Plasmaman plenum
NPC button clutch
Custom 3.5 inch Catless exhaust
  • Like 1
  • 3 weeks later...
- Adaptronic​ ECU
- P98 Fuel, 352rwkws @22psi with exhuast dropped before cat.
Finally got my car on the dyno, nothing special but I just wanted to know what she was running.
2000 R34 GTT
Unopened RB25DET NEO
Standard OP6 turbo @ 10psi with boost tee
HKS return flow intercooler
Splitfire coilpacks
Pod filter with stainless intake
Split dump
3inch exhaust
De-cat
190kw Shell V Power 98 (Normally run BP98)
Standard fuel pump
Standard injectors
Standard AFM
Standard ECU
Videos (facebook won't upload HQ):
https://www.facebook.com/jake.stirling/videos/972992202758804/
https://www.facebook.com/jake.stirling/videos/972992936092064/
  • Like 1
  • 3 weeks later...
2000 R34 GT-T
Unopened rb25 Neo
Garrett Gtx3076r .083 V band
6 boost high mount mani
Plazmaman plenum with throttle body
Plazmaman fuel rail
1000cc Deatschwerks Injectors
Walbro 465 Fuel Pump
Turbosmart FPR
52mm 6boost progate
Apexi Power FC
Z32 AFM
Hybrid HDI intercooler
Splitfire coilpacks
Greddy Profec EBC
Direct Twin Plate Clutch
Tuned by All Star Garage 412hp @ 20 psi.
  • Like 1
  • 3 weeks later...
My current setup is as follows
340rwkw @17-18 psi on BP 98
Rb25det Neo
Stocks gasket and head bolts
Stock motor
Tomei Type B Poncams
Kinguawa T67 25G 10Cm
Nz performance Hi mount with 44mm gate pipe
Tial 44mm Gate/38mm screammer pipe
Greddy FFP
VH45 TB
Greddy Twin entry Fuel Rail
Sard 880cc Injectors
Sard fpr
2.5" cooler pipeing
Greddy Type M intercooler core
3" DUMP
Blitz Nur Spec R 76mm
1999 R34 GT-T Coupe
Unopened RB25DET Neo Engine
Hypergear ATR45SAT Turbo
HKS Cast Low Mount Manifold
Turbosmart 50 mm External Gate with Screamer Pipe
Xspurt 1000 cc Injectors
Walbro 400 lph Fuel Pump
Tomei FPR
Greddy Profec B-Spec 2 EBC
Nistune
Z32 AFM
Just Jap 600x300x76 FMIC
3 inch Custom Dump + Front Pipe
*3 inch 100 Cell High Flow Cat
*3 inch HKS Hi Power Silent Catback
3 inch Metal Intake Pipe
Blitz Stainless Steel Pod
Blitz BOV
Splitfire Coilpacks
Denso Spark Plugs
Stock Intake Manifold
Stock Cams
E85 Fuel
348.7 rwkw @ 22 psi with HKS Hi Power Silent Catback
*365.1 rwkw @ 23 psi with the Cat Dropped
Edited by statue
  • Like 1
Guess I'll post my latest dyno run, after adding in an addition 6 degrees of timing up top and about 4 in between 3900rpm and 5400 rpm the motor refused to make any more power. Ended up making 327kW but I was leaning too much on the timing so scaled it back and she made 325kW on E61
1996 R33 GTS-t, probably has 300000+ kms on her (Edward Lee's Special Edition)
Unopened motor with:
  • Hypergear SS2 (older version, circa 2013)
  • Turbosmart Hypergate 45mm External Wastegate - off the rear housing of turbo
  • 875cc Siemens DEKA IV E85 top feed injectors (half height)
  • Turbosmart FPR1200 Fuel Regulator
  • Walbro 450L E85 Fuel Pump
  • Plazmaman Swept Back Intercooler Piping
  • HDi 600x300x76mm Intercooler
  • Splitfire Coilpacks
  • ARP (non-2000) Head studs, torqued to 108nm with Assembly lube
  • Mocal Oil Cooler with GREX Sandwich Plate / Thermostat
  • China 43mm Ling-long Yumcha Radiator
  • Calsonic Power steering cooler
  • RS-R 3.25" dump, flange chopped with 3" V-Band
  • DIY 45mm Screamer Pipe
  • 5" Body Venom Catalytic
  • 3" Fujisubo Catback Exhaust, with X-Force Resonator and X-Force Mid muffler
  • Zeixtronics ECA Kit
  • Adaptronic 440 Select
  • Blitz DSBC Boost Controller
  • Stock Cams, Stock HG, Stock Intake Manifold, Stock Exhaust Manifold
  • Self Tuned
440rwhp @ 20psi on 98
Unopened rb25det neo
GT35R .82 rear
High mount t3 6 boost
Turbosmart 48mm progate
Link g4+
1000cc ev14 deautchworks injectors
Turbosmart 1200 FPR
Tomei type a poncams
China freddy
Unknown intercooler
Apexi safc boost controller (apparently having a hard time regulating boost, will be throwing out for next tune)
  • Like 2
Nismo 740CC Injectors
Z32
HyperGear ATR45SAT IWG
Apexi AVCR
Stock manifolds
3" Exhaust
Blitz Return Flow FMIC
Nismo FPR
Splitfire Coilpacks
Walbro 460LPH
Turbosmart PB BOV
Stock airbox
BP98
289KW @18PSI
5295311E-1770-4210-9BE2-8E9CF17A231F_zps
Edited by kingtube69
  • Like 3
Quick write on the R33 build. Parts list of mods done,
Intercooler
High flow plenum (greddy style)
6boost exhaust manifold
Garret GTX3076
Haltech platinum pro
740 injector
45mm Turbosmart hyper gate
Splitfire coils
3inch exhaust
Walbro 400 fuel pump
Partial rebuild on pre-loved motor, ring landing where stuffed on 1 & 6 piston. New rings, piston & bearings for the block. Head got a look over as well with new stem seals and abit of a shave.
Now the R33 is sporting a solid 320kw @ the flywheel, & 266Kw @ the wheels on 14psi[emoji39].
Edited by Smylie79
- Adaptronic ECU
- HyperGear Turbochargers ATR43SAT (Prototype 031215) Ball bearing, Internal gated RB25 bolton Turbocharger
- Havoc Fabrication 3 inches turbo back exhaust with 2.5 inches bleeder valve.
- Tuned by Trent Hewitson, Chequered Tuning.
317rwkws @ 21psi P98 fuel, 20psi @ 3550RPM:
R33 gtst rb25det unopened
Hks gt-rs turbo
6boost manifold
38mm tial external wastegate
Nismo 555 injectors
Nismo FPR
Splitfire coil packs
Blitz return flow intercooler
apexi power fc
Z32 afm
3 inch exhaust
Hks bov
Walbro fuel pump
Exedy clutch
270kws
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
