I want to buy my partner wheels for his R33 GTR skyline can you please help with a few questions - Do the rims need to be the same width all round? Or can you use narrow rims on the front with the same width tyres? Also if going to 19” rims what size tyres should I get him?
I have spoken to a major tyre shop and they were very unhelpful. Thank you very much!
https://www.sau.com.au/forums/topic/57911-girl-needs-help/
Guest two.06l
Thank Richard!! The rims will probably be 8.5" so what size would you suggest??
P.M. Wreckedhead as he has R34 GTR rims with tyres ready to go. Its widely recognised that these rims look hot on a 33 GTR.Heres a link. http://www.skylinesaustralia.com/forums/sh...ead.php?t=56621
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113434
JustJap also have a set of R34 GTR rims for $3K (they're 18x9) and look hotness.
For 9" wide you should get 235's stretched, or 245's. I'd get the 235's stretched as there's no sidewall flex, problem with this is that you gotta make sure you know how to park otherwise you'll gutter rash them to hell and back.
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113454
Don't get 8.5" wide, get at least 9" wide since thats stock width, OR 10" wide fit as well..
same size wheel AND tyre all the way around...
Go witha good brand, not something cheap like ANZ etc... It may be worth asking your bf what he wants, it would suck to spend 4k on wheels/tyres to have your bf not really like them :D
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113465
no worries, happy to help PK.
Like the other lads said, I'd suggest 9inch wide +. For me I think 18X9 is a good size for a 33GTR and the tyres will be a little more affordable than for the 19s. If he's really keen on some BIG wheels though, then 19s would be the way to go.
happy wheel hunting.
Richard
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113490
I second/third that you will need all the same all around.
I also think that if you're going to the trouble to get new wheels for him that they should be wider. 9" or 10" would look really hot, especially with a 235 or 245 width tyre stretched across them.
I'm not sure about offset as I've never owned/fitted a skyline let alone a GTR!
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113493
If your going for a 19 inch rim best bet would be to go for a 19x91/2 with a offset of plus 11 for a 33 or 34 GTR and the correct tyre is a 275/30ZR19 this will give you the closet to the correct height this is what Rays Engineering recommand for a 33 or 34 GTR, for 18 inch most use 18x9 with a 265/35 tyre i wouldn't go under 245 as this is what 33 and 34 GTR's came with so if you wanted to keep costs down go for a 245/40ZR18 . Also the PCD is 114.3
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1113971
r u guys sure the wheels have to be the same size? cosa the ones on my car are 8.5 on the front with 9.5 on the back, with 255s all round
and the tyre placard says the tyres are different sizes, like rear was about 15mm wider, can't remember exactly what size, i'll have to check tomorrow
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1114073
Nuh if you have different widths on a gt-r the attesa 4wd can stuff up. All gt-rs should have the same width wheels
yeah the torque split gauge goes crazy. It happens on a friends car who has different sizes.
As for the 19's I agree with gtr13, go for 275/30/19 on 9.5 inch rims.
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1114200
I thought the GTR's came with wider on the back standard.
This is what I've seen on every GTR.
Could you show us the GT-Rs you've seen with different wheel widths front and rear? It's possible you saw GTS-ts or GTS25t's that had GT-R badges on them... not GT-Rs.
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1114299
hmm you're looking at a big tyre bill.
thats for sure, especially for 19" rims. I would go for 265s at least...depending on how much hp the car has or will have. Cost big $$$, but has a sweet footprint.
I have 265's all round on my gts-t (bit of over kill seeing as only driving the rears) but looks hot with the wide treads.
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1114773
Hey guys, thankyou all VERY much, you'ra great!. Just one more question - Is there a measurement or what is it called when one wheel looks narrower but isn't - sorry if this doesn't make sense, but at the moment the car has the same size rims on it, but the spokes on the front wheels are closer out to the tyres, while the spokes on the back wheels are a lot deeper in.
Thanks again!
https://www.sau.com.au/forums/topic/57911-girl-needs-help/#findComment-1114780
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
