  • Replies 59
Dont you know JimiH?? They need to raise more funds the the Police Xmas party :D
Im all for girl power n girls in power n such ...... but her and Alannah McTiernan have no idea :)
hahhaa nice one Bully, i just sent her a nice long email :D
bet she doesnt even read it the stupid cow!!!
I sent one about the anti-hoon laws a while ago, it took her 2 months to reply :rofl: must have been busy making more new laws.....
I don't read the things about where the camera are in the paper and on the news (would most likely forget where they are anyway), but it still isn't a good move.
hey paul... hows about manufacturing a few of those puppies yeah
yeah not a worry.. the other option is to attach it to a electric pully system. flick a switch numberplate goes up, turn off numberplate goes down... james bond style
you guys are headed for what we have in Vic.
The cops are not driven by the law, and upholding it.
they are driving by revenue and even lying to give you a fine... then it goes to court... and you loose as its 2 cops word against yours.
you should all oppose it as we have it bad here with fines.
$480mil last year revenue...
the Vic cops then try say that 3km/h tolerance for speed camera's is too save lives.
The road toll is higher than last year when it was a 10km/h tolerance
yup they say this is all to save lives but we all know that the truth is the multis just aint bringing in enuf fold no more
an the death toll jus keeps goin up f%$k multis put more well trained inteligent (sAfrican American, sAfrican American) cops on the road instead
oh an just a hint if you dont want to get done for speeding do it on some little residential street where you might hit a kid cause your garanteed these fund raisers aint never gunna be set up in low traffic areas even if that is where speeding is most likely to cost lives (stupid make money over save lives policies)
:rofl::D:rofl::rofl::rofl::rant::rant::rant::rant::rant::rant:
i heard a long while ago that some countries or states in the world done away with camera's and found it make no difference in the road toll.
i think NZ's camera's flash everyone, but they only fine the top 10 or 15% of speeders, so if you drift over the limit or what not else you are safe
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
