OH...LOL. Was speaking to Ben about getting car tuned once i have had a little fiddle with the exhaust. He started laughing at me, "so your Roy":( Who has been talking out of school about the Amazing Flaming Roy:)
Seems like a tops bloke and very knowledgeable, general chit chat over the phone has left me at ease/comfortable about the work that will be getting done. So things are looking up for the old girl.
Perhaps its time that i start talking it up again:)
RB20 POWAH:D ...or something resembling power:(
  • Replies 314
Hey All,
Just had a bit of bad news and looks like an 'unthoughtful' (just j/k) friend has scheduled a funeral on the 5th :(
Will check with the missus about times and stuff like that to see if I can do both....otherwise I have a very hard decision to make :(
(Have you entered with a GTR Shiv?)
I wish. I have a better chance of getting on the track with a shopping trolly at the moment. Not sure how I ended up being listed on there but i've taken myself off. I'll just be the camera bitch again :)
Hey all,
To put the debate to rest.....its a gtst :)
I've had some good news at last and will be able to make it...yay....form sent in today.
Hey Roy I'm still waiting to see how my line goes against yours on a track.....you going to make this round??
Ok - Im going to meet up with the WRX Club motorsport committee tomorrow night to cover a few things. Including the requirement for a tow hook. It's in their sup req's but currently I don't think any of us have got them so I will confirm if they are required.
I've also heard that the wrx scruteneer's may not like the positioning of where most of us keep our extinguishers. (In the back) Again I will check this out so that we don't have issues at the first meet.
Finally - geoff - I think we have a newbie that needs a bonnet strap. Cheers mate.
I dont now about R33/34s, but R32s do have tow hooks std, so may just need a decal to show safety crews the location.
I suspect if you look under your cars they have tow hooks std, how else do they get your car onto a table top truck...or am i missing something?!?!?!?!
Is the 3rd GTR Marcus?
Yeah but they may require an external tow hook because your car may be burried in a sand trap. I dunno. I know you can get external tow hooks - I personally dont want to have to get one however.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
