  • Replies 58
Someone on the forums has one of those front bars, its a red r32 gtst, i think he has it in his sig along with his mkiv supra.
Thats coco69, 32gtst is currently up for sale http://www.skylinesaustralia.com/forums/sh...ead.php?t=56404 (pics of trial FB here)
I reckon the trial frontbar looks awsome....
I wont ask how you come across that picture pentae, but its not wrong to put a GT-R kit on a GTS or GTS-t, it improves the look of the car as a whole without making the car over the top, i'd rather see a GT-R kit on a GTS-t then an Abflug creation or something like that.
My opinion would be don't bother about the RB25DET
Just work on the RB20DET. I was happy with my GTST, till I went to the circuit, didn't feel fast enough or handle like I wanted. I was lapped by GTIRs for gods sake (JOKES :) )
my mates Evo IV made me feel like I was standing still with foot flat. here are the mods I had on my last car, I sold to some guy I haven't seen since (worries me:( ):
Engine Performance
105, 000KM's. Major service performed by just jap at 97, 000KM's. All other services done by me at regular intervals. Platinum plugs in there and gearbox oil was changed at major service.
3" exhaust from the turbo back. Dump pipe and front pipe are one piece fitted by just Jap
K & N panel filter in the standard airbox. Removed POD that was on there.
Turbo XS Dual stage Boost controller fitted and set for 11PSI on low, 15PSI on high.
Bosch 550HP fuel pump has been fitted as it was leaning out on the standard one.
HKS FMIC Kit bought from japan brand new and fitted. Front bar modified to fit.
Suspension & Braking:
Koni Adjustable Shocks and Lowered springs fitted, Height and Damper adjustable
24MM Front sway bar & 22MM rear sway bar with new D-bushes fitted, and new pin bushes
New Radius Rod bushes fitted and Full Alignment done
Front and Rear DBA 4000 Series brake rotors fitted with Bendix advance pads (last few months)
Motul 600 racing brake fluid
Calipers painted RED
New 17" Work Ryver Wheels fitted, Purchased BRAND NEW. tyres are in good condition. Wheels are, Rear - 9" wide, Front - 8" wide
Interior:
Momo steering wheel and boss kit & Nismo aluminum gear knob
Recaro Drivers seat, decent condition (also includes immaculate std drivers seat as is passengers immaculate) CRD seat covers used all times
Pioneer CD player (entry level deck)
Boston Acoustic Front 6 an a 1/2" speakers
Pioneer 6 an a 1/2" rear speakers
Alpine V-series AMP running all 4 speakers. 350WATT AMP
Greddy 52mm Boost gauge (reads to 1.5bar)
MISC:
Rear Guards Lipped to suit wider wheels
Philips 4300K light globes fitted
10% dark tint on all windows except front
Inbterested to hear about your TD06-19C results. Keep us posted.:)
Provided the tune isnt a hand grenade, and your engine isnt a liability to start with, i think you will have to be trying pretty hard to kill it:)
car lands from jap in 3 wks... the car has 180,000kms on the odo... unsure if engine is newer or not - so im going on the fact that its an ex track car, its gonna be shagged if its still using the motor it was built with...
obviously a compression test is going to prove wether im right or wrong...
if comp test comes up good - im giving it 3-4 months max before motor goes pop - then its neo-6 time :kick:
also the rb20 in my car has tomei cams (unknown duration or lift) so hopefully theyll help with the spool time... as you would know the 19c is only an 8cm exhaust housing so i will be losing a bit of top end compared to a 20/25g... this 19c should max flow at about 260rwkw on 1.5 bar... least my greddy type r bov will vent with this turbo hahaha
ill keep you guys posted
oh and on a sidenote - just temp due to the fact im a bit short on cash... 550cc FC rx7 injectors should last me a lil while for 230 odd rwkw right?
- adz
When you get rid of the engine, i bags the cams...seriously, contact me when you are done with them.
As for the turbo you are installing. "19C" refers to the compressor, and the 8cm refers to the exhaust housing size. The 20/25G alos refers to the compressor wheel size of other Trust turbos, but as they are all TD06 generically have the same turbine/exhaust wheel. Some are TD06, some TD06S, TD06SH etc etc.
And at the power levels you will be running i dont think the 8cm housing will hurt top end too much, especially if you have cams. The TD06 is a decent sized turbine and flows plenty of air, so i wouldnt be too worried. Im actually tryin got shop around for an 8cm housign for my TD06-20G just to compare the results with the two different sized housings:)
So your19C should be more responsive then my 20G as the compressor wheel is smaller so less inertia, and you are also running the 8cm housing rather then the 10cm housing like me.
I have never seen results of the 19C, but my 20G on a std RB20 running 16-17psi makes a comfortable 220rwkws. If the tune was not so conservative i may make a bit more power, i would be very interested if the 19C on your car makes the power you are aiming for on oump uleaded.
Forgot to mention that it now has an R34 GTR FMIC, and an Apex-i N1 GTR turbs back exhaust, plus I fitted a 1100kg 9 puck ceramic clutch.
(And no, I dont want a GTR, parts cost too much- bar a std cooler which i got for a good price, and I have enough fun in my GTS-T!)
Reliable fun :)
Steve
Pentae have u ever conisdered that people who have gtst can afford a gtr but choose not to buy one? or have you considered the reasons i am fitting the gtr bonnet and rear spoiler, that is to lower weight and increase downforce ???
or are u a narrow minded bogan whos opinion no one values anyway??? :flamed:
should be a hard one... anyone???
Although some people disagree, I think fitting GTR bits to a GTSt is ok. I prefer the GTSt rear spoiler (on a GTSt :)) but the GTR grill and bonnet looks horn on any R32.
If I'm honest with myself, if I owned an R33 GTR I wouldn't feel bad fitting a 400R bodykit to it.
Each to their own, whatever starts your engine and all. That said, I still laugh at the Civic-spec "R34 GTR" that was for sale on eBay a while back. Oh yeah, and the SerIV RX-7 on Prestige's website that has the Ferrari bodykit.... and the MR2 on J-spec with the Ferrari bodykit.... *groan*
Dude, relax. Rise above having a go at people. Choose to disagree and leave it at that eh?
Mark
roy - thanks for the refresh but im fairly up to speed on trust ID figures :P
generally all 19c's came with an 8cm housing so...
but moving along - only 220kw? very conservative tune... and 16psi isnt really in the turbos efficiency range (borderline opening the door to the G spot of the turbo)
20g will max flow at about 290-300kw... so youve got another 80kw if you ever need it sitting up there in the top end (around the 24psi area)
- adz
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
