Hi B5URK,
There is an alternative to getting a new head unit, which is the FM modulators that change the frequencies.
Jaycar, Strathfield and any number of car audio places will sell you one that usually changes the range by some number (best to get the one that changes it by 20Mhz as then it makes sense ie. 101.9 becomes 81.9) and then everything else works OK. These converters use std australian aerial plugs though, so check what kind you have before you start.
Good luck
Ned
  • Replies 49
  • 3 weeks later...
what to do if yours is cut off?
lol
i'd follow the cut wire until u find the next connecting point and replace it from there...
better than solderring it in my opinion. but i dunno if its a lot of trouble to do this. probably is actually :rofl:
Is this the same power wire that raises/lowers the antenna when the stereo is switched on? Or is there a separate wire for the signal booster?
make sure you connect the power-antenna output (usually the blue wire) to the black/red wire in the centre pin of the factory headunit plug. This powers the factory antenna signal booster.
There is another black/red wire next to it but it's a speaker wire.
  • 3 weeks later...
Hi Guys,
Went in to my local Auto Barn shop and ask for a device to allow me to pick up 90+ Mhz range of radio station and they gave me this:
Aerpro FM Antenna Booster - AP342
On the back it says:
Amplified FM Antenna Booster in or under dash mouting.
Power Frequency gain 88Mhz > 10.5dB, 98Mhz > 10.9dB, 108Mhz > 9.5dB.
Can anyone (Chris Rogers??) confirm that this will allow the standard R33 radio to pick up aussie stations? I guess from reading this thread that I will need the antenna convertor too??
Thanks,
Justin.
  • 1 month later...
Ok so i have bought the antenna conversion adapter from Autobahn and here's the thing, my car is different from y mates. EG the antenna adapter he bought is different from mine, should this be so? Once i sort this out can i remove the Jap antenna's from teh back of the car or do you ahve to leave them there?
ben,
what does your car antenna look like? if its the two pin item them you should have AP348a as the antenna adapter. post a pic up ( or email [email protected] ) and I'll help.
ben,
Yeah its a 2 pin plug and the AERPRO adapter i got is a AP348A
  • 1 month later...
Guys if anyone is looking for the antenna adaptors I currently have a couple of the Aerpro AP348A adaptors brand new. Bought two and didn't need them in the end. $12 will get you one delivered via Australia Post. PM me if you're keen. Vijay.
  • 3 months later...
  • 8 months later...
i just got car a few weeks ago it said "alpine stereo" on the car add however when i took it for a test drive i didnt play with it to busy listeningfor all those little sounds like gears shocks bakes and so on. so now i am left with a japanese double din head unit with mini disc player, problem is not even the cd player works on it.....or the stacker in the boot alls i can get is christian FM...FULLY SIIIIIIIIIIIICCCK MATE!!!! i pic up all the chicks now
i think im going to rip it out this weekend and chuck it in my fire place, bye bye alpine its time to die!
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
