Hi all,
After recently doing a driver training in my car, I have discovered the aweful stock handling flaw in most whales called understeer. This was also emphasised by the instructor who's words stick clearly in my mind "TURN YOU UNDERSTEERING PIG!".
Well, I want to correct this situation. Saying that, it's a street car, I don't use it for the track but I may do an MC Motorsport type competition from time to time.
My question: What is the best way/what are my options, to fix this understeer? I'm not keen on changing tyres so i'm talking more suspension mods. Car is currently stock suspension wise.
Any help you could provide would be appreciated.
:D
https://www.sau.com.au/forums/topic/62711-correct-understeer-r33-gtst/
Thanks for all the replies. For the driver training, i already had the fronts 2psi higher than the rears but I hate my current rubber so that will definitely be the first change.
Would I be worthwhile simply purchasing something like the Whiteline "Handling" Kit or should I just go to a local suspension shop and get them to supply and fit the bars and camber kit?
The only thing I would add to what the guys have already said is add some positive caster, get some adjustable radius rod bushes (Whiteline have them). I would not suggest much negative camber for a mostly road car as it wears the tyres, around 0.5 to 1 degree negative is OK.:P
  • 4 weeks later...
Pretty sure the only (well major) problem is your rubber, what are you using? I was using Falken’s and they cornered like crap, now I use Michelin SP Pilots and they stick very well. If anything I have over-steer with them :D
It has been my experience that having the same tyres front and rear maintains the handling balance. So upgrading all four tyres will not improve the understeer, you may raise the limit, but eventually it will still display the same predispoition to understeer that it currently has. Much better to fix the problem (ie; adjust the balance) with suspension geometry correction.:)
Thanks for all the feedback, really appreciate it. I definitely have a problem with my rubber as i hate my tyres and obviously that will help but like SK said, suspension geometry is my major area of weakness. I think i'll be looking more into those Whiteline "works" packages..
Cheers!
you are far better fixing up the underlying handling problem before you improve tyre grip. Improving typre grip first will only hide the problem. Fixing the handling while still using the poor tyres is easier as the change should be more apparent and also should be obvious at lower (ie safer) speeds
brendan
also where is it understeering? corner entry? mid corner?
if its corner entry perhaps checking the toe in on the front would help as well, bit of toe out will improve the turn in at corner entry!
Then it could wander a bit on the straight stuff.
Anyway, arent most cars designed with understeer to allow for the 'lowest common denominator' people???
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
