  • Replies 58
but why would you want to go that fast?
Because he is a Kriminal.
Pay what ever it costs you test your top speed at your local track.
Its a lot safer and will prevent you making the news WHEN not if you get busted.
"Yet another Skyline clocking 200km/h"
Its not some thing we really want to hear.
Now that you have reworded the origional post. :cheers:
That really depends on how much power and rev's you have.
I would say 240-250-260km/h is within reach.
My little old VS Commodore 5 speed with a few mild mods used to only 'just' crack 250km/h so no doubt a mild RB25 which makes around 380hp will be able to crack it also. Depends if you run out of rev's.
Do the Math. :D
The standard soft limit is fifth gear at 5000rpm. at that speed you are doing approx 190kph
If you divide by 5000 and then times it by the redline (7200), you get 273.6kph.
Didnt you learn about ratios in school?
Soft limit? What's that then? Haven't heard that expression before.
so at 8krpm you'd be nudging just over 300km/h? Must try that out!! (Private closed race track of course. :cheers:
Adrian
You don't even need 250hp to crack 250km/h.
haha.. Come on buddy.. This is a VS 5ltr Slugger Commodore we are talking about. :P
250km/h is a fair speed, most new cars even the ones making 250hp at the fly would be pushed to get 250km/h.
I was actually referring to the bit where you said "no doubt a mild RB25 which makes around 380hp will be able to crack it also."
...and im saying you dont even need 250hp to crack 250km/h (and you dont even need 7,000+ rpm).
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
