  • Replies 58
Benm,
So the R33 N/A ~150kw will crack 250km/h.. :D
I don't think it would. :P
I am unsure about the N/A but I can assure you that a 250hp (186rwkw) RB25DET is very capable of pulling 250km/h (and still pulling beyond that altho quickly running out of rpm before the rev limiter).
Lets just say I have a friend that has a flat private driveway to his house/property with plenty of run-off room where hitting 250+ in an RB25DET is very achievable.
Benm,
well I know I also took a stock pulsar over 200 with
but I think things get much harder over 200, thats a lot of air to push out of the way.
A dyno can only tell you the wheel speed of the car at the rev limit in 5th, there is no way you can max out a standard car no matter how long the road
uh?
I agree with Bazelinez, the speedo and real world speed do tend to be out slightly. I know on the private road i use, my PFC reads 180 as my speedo nudges the little "HICAS" light off the end of my 180km/h stock speedo. at 200km/h on the PFC, the needle was just past the HICAS light. :P
well thats an interesting question.....personally I'm surprised a PowerFC would read different to a speedo since they both use the same sensor in the gearbox :confused: I think the main issue is the rolling diameter not being exactly right for the speedo
IMHO GPS or good accelerometers are the only accurate way
Benm,
I miss-understood you. :D
...and im saying you dont even need 250hp to crack 250km/h (and you dont even need 7,000+ rpm).
You then said your friend with a Rb25DET (which is 250hp) cracked 250km/h.
The N/A won't cut it. 250km/h is just too much air to push out the road.
This friends R33.. Was it dead stock? or had the usual exhaust?
How did it go towards around 235-250km/h. Torque would have been dropping off at that point so I would have to assume the last 10km/h were slowish.
Pulling hard is subjective.
Honestly, I really do find it hard to believe a stock R33 (including ride height) would zip up to 250km/h without a struggle, think it would really be pushed to get there.
But its all I think. :D
I believe 230km/h is a fairly easy target but after that things slow down quite a lot and takes quite a bit more time to get there.
Well if a little old corolla can do 8500rpm in 5th (3SGTE, but pretty much stock) then I think a skyline could do better.
BTW, working it back and allowing for the speedo being out, the rolla was doing anywhere from 270kmh+ (sits on about 2800rpm in 5th at 100kmh, but we know its more like 90kmh. So if anyone wants to do the maths)
I have some bits to add to this all done in safety offcourse. I have an apexi digital speedo for my r33 with some small mods to the car. At about 100 on the standard clock but the apexi is reading 105 and the gap increaces slightly the faster I go, but the top speed i have done in safe envronment was 260 on the apexi.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
