  • Replies 44
DoughBoy,
I tried to send you a reply PM but SAU is having dramas. I will take the item considering it bolts straight up. Just out of interest does it come with the mounts and bolts or will I have to source them?
Also with the postage......do you live in Sydney or Melb? If so I might have an easier solution. Let me know via PM and hopefully the system will be back up.
Thanks mate.
just wondering did anyone buy any of these turbos off him and actually get them yet? I gave him money for the N1's and now it takes days to get replies from emails and even then its not much.
Not saying hes not going to send them or anything, just interested in hearing from others about it.
DoughBoy is reliable mate, may take a while but he is quite busy. Got my HKS dual dragger off him last year and damn its good. Bloody loud though! hehe
Might be reliable but **** he takes days to reply, it doesnt take much to take 5min out to email or call back.
Last email I got from him was 4 days ago and hes not answerin this mobile number he gave me, when the turbos were meant to have been sent by today at the latest. just all a bit suss.
When im selling stuff I have the decency to take a few mins out to let the buyer know what is happening, doesnt take much effort and they dont need to worry as much.
Chris is as reliable as they come.
He works like a dog, and is extremely busy. He gets up late as he works late through the night. Try calling him in the afternoon.
Don't worry, you'll get your parts :cheers:
Ok fellas thanks for that. Figures as most of his emails are sent like 11pm.
Only reason I uses DD rather than cod is because ive been reading this forums for awhile and know hes been around and seems like a good enough fella, so assumed he wouldnt try rip me off (which he hasnt)
He wont rip u off dude, he is very reliable, like merli said he is very busy running a business if you contact him he will be working he's always working, send him a sms or ring him in the arvo, u'll eventually get him..
Chris calll me got to talk to u......
Check his feedback, the guy will go out of his way to help you out. Hard to find something like that thesedays...
:jump:
:jump:
:jump:
his busy as **** and doesnt have time for even a beer with mates......
he'll come round :headspin: :headspin:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
