I can never understand why people do this!
If the engine bay looks dirty then use a rag and clean it by hand!
water and electrical connections do not mix!!!!!!!!!
I live on a dirt road. Cleaning with a rag isn't an option.
Besides, other reasons could be oil leaks etc. May have to degrease to find where the oil is really coming from.
There are many reasons to do it. Just gotta do it right so not to harm anything.
High pressure however is a HUGE no-no near engines IMO. If I can get 3 inch of clay of a dirt bike engine that has baked on there, with not more than garden house pressure, I can't see the need for a high pressure hose on a car engine!
Ah I knew I read something on here not long ago.
Here is a guide for detailing your car.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47397
and http://www.carcareonline.com/viewarticle.aspx?art=4 was one of the links within the thread.
thx heaps for the feedback guyz,
yeh im definately not doing that again.
anywayz so ive disconneted all the terminals and ive let them sit
will that be enough to solve the problem?
btw where is the coil pack? and yes i do have a pod but being the dikwad i am i didnt cover it, how do i fix it?
dude, if u have wet the pod filter. STOP running the car...you want to get all the water out of everywhere first. It seems you have been running it a fair bit, so with a bit of luck it is just the coil packs.
My advice would be to not start the car until you have checked out the things mentioned above.
Do a search on coil pack servicing
Pod filter - I'd disconect it, sit in the sun until it is TOTALLY dry. See if water has gone up the pipe between the pod and the engine, if it has, might pay to remove the pipe, make sure it's all gone.
If you have water in the engine it is a VERY bad idea to be turning it over.
I am used to drowning dirt bikes, but not cars, I would assume it's the same idea, any place that water may have got, check it out, clean it out, dry it out.
On bikes after all that, you take the plugs out and turn it upside down and turn the engine over to get it all out....but I am guessing you don't do that with cars! hahaha (how funny would that be tho..*mental image*)
i know what your saying ? i say there is water traped under your coil packs as ive had the same thing happen to me i just pulled all my plugs out clean the packs with CRC and plugs put all back and done problem fixed ? and while your plugs are out turn your motor over blow any water or moist out of the bores if u have any good luck with things
When cleaning the engine bay a high pressure spray and degreaser, I made sure to cover the air filter with a plastic bag. I forgot to take the bag off afterwards but luckily I remembered just before I drove off. The car would have had a hard time breathing that's for sure.
We used to jet wash engine bays in one of my detailing jobs. Cover the fuse box (if under in the engine bay) and the alarm siren box. Quick flick over with a truck wash canister, then three times accross the bay with the jet wash to form not much more than a mist.
We always left the engines running as it would be hopeless trying to start it if something got wet.
Any idea of quantity of water or time spent purely on the engine bay with the jet wash? Seconds or minutes?
Hope it sorts itself out mate
I would get a high pressure airline and pull all of your electrical connectors apart and blast all the moisture out then spray with WD40 or similar product. Pull the coil packs out and do the same to them. dry your fully sick pod filter and put that back on.... You cant have done much in the way of damage. If the car sounds like it is missing its most likely because there is water in the coil packs and its shorting out... Just be carefull next time you wash...
P.S unless you had the hose on the air filter the engine wouldnt suck in enough water to hydrolic lock the engine so dont worry about that dude.
dry her out and then take it for a good run to get everything hot and the remaining water will evaporate and you be sucking the doors of HSV's and WRX's before you know it..
ENJOY!
  • 2 months later...
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
