updated again:
fixed missing image
fixed spelling mistakes
fixed grammar mistakes
added hyperlinks for each section
added section split based on content
added self tuning - fuel economy
added info on changing airflow meter
added info on powerfc tune protect
expanded info on tuning options and expected results
do they release slightly differant maps in the diff versions of the pfc/hand controller maybe ?
I was comparing my ign map to the one in the faq, and in some points (outside of the first 10x10 range) they were off by like 10 degrees. I also compared them to the ign map in the FC PRO software, they was differant as well.. ??
Mine is pfc v 5.11, and hand controller v5.01A (might be the other way around)
Wered you grab the stock map on the faq from ?
as far as i know the stock maps don't change very often
i havent at least heard they do. they were taken from my tune
but i may have done it before i did factory reset so they could be a "tuned" ign map. when i get datalogit, ill copy mt tune. reset to factory defaults then upload the defualt maps to my site and then restore my tune and upload that as well. ill expand the powerfc faq a lot when i have a working datalogit
added boost control pics, info and wiring
added djetro harness and wiring and manal
added datalogit specific extra features
added datalogit logging options
added datalogit additional functions
corrected spelling mistake of my name
corrected double up paragraph
updated again:
added airtemp sensor on unsupported car info
added powerfc inside cover photos
added reflashable powerfc info
added custom hack / diy / hand controller holder pics
added basic hand controller use
added checking sensors
added checking functions
updated install info
those 2 manuals are old as the hills and are for rx7. They are also the older powerfc so its not upto as the japanese SR20/RB25/RB26 manual.
it comes off the main wiring haress which i think is a digital output from the gearbox somehow, ill find out
It most certainlly a gearbox feed... The only other alternative is the ABS sensors but it still works on non-ABS skylines so it must be a gear box feed....
Plus the skyline has a digital sendor to the dash display....
hey guys i have a question for those in the know
because the nvct cam timing is constantly variable on the NEO rb25, can the PowerFC be mapped for this function, or how does that work?
with the r33 rb25 its either full advance or full retard no inbetween. and is activated by a simple on/off switch in the ecu at the desired rpm.
anyone know how the powerfc and rb25neo nvct perform?
is it completley mapable throughout the entire rpm band or whats the go?
no idea but if you find out let us know, will add to powerfc-faq
the vvt on the rb25 (33) isnt controlable and its automatically controller by the powerfc emulating stock ecu functionality. you can see it turn on and off under check sensor / sw but its not controllable or editable in map form
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
