the stock maps are fairly rich for protection reasons but it should still enter closed loop on low throttle. as long as 02 feedback is turned on of course. 250km's to a full tank is resonable in an un-tuned state
Quick Question...
- AVC-R
Or
- Boost Controller Kit
for Power FC?
Is it personally preference of would the boost controller kit for the PFC be better cause its also controlling the rest of the engine as well as being cheaper than the AVCR (AVCR = $580) - (PFC Boost Controller = $400)
Give me your thoughts...
so no disadvantage/advantage over the two... apart from having an AVCR on my dash and someone decides the would prefer it off my dash and in their corolla :D
It has a bit of a wank factor... Also with the PFC do you have to leave the commander connected all the time, can you like take it on and off at will if its in the way or soemthing?
After reading the faq, I still needed some more convincing on the PFC with an auto, so i've made a new thread so as not to bring the conversation into here:-
http://www.skylinesaustralia.com/forums/in...showtopic=97698
So yeah, i want to know once and for all if the PFC will work with the auto.
Cheers.
hey ive have plugged in my power fc and its hasent been tuned yet.
the engine light stays on and the car constantly stalls. it also feels like its skips and hops going up through the rev range. all was fine with my stock compter.
i need to keep the powerfc in fow a couple of weeks till i get it tuned, is there anything i can do to fix it? like reset it or sumthing?
make sure the boost controller kit is turned off (says that in the faq) and if that doesnt make the engine light go off, try a full reset via ETC then turn the key to ACC, turn off boost control kit and then start car and let it idle for 20 minutes. follow the procedure correctly for first time "init" of the powerfc as it has to learn the idle
I dont know if this has been covered but I just found you that you can get number rating for the knocking levels with your car.
Just press the UP arrow, and it will show digits for knocking. So basically it will show you the peak, in a digit and not just upon the bar graph
updated:
added boost control kit hookup
added boost control kit configuration
added boost display without using boost control kit
added apexi other piggyback systems
corrected grammar with powerfc pro
expanded more on apexi boost control kit functionality
Paul
I bought a AVCR boost pressure sensor from Nengun. I have a 3 pin plug for my power FC. It reads boost but its wrong. I have my set my boost pressure at .65 bar via the power fc to read 20psi at my guage. My low boost is set at .50 bar.
I believe something is wrong with the boost pressure sensor? I had to manually wire it up as it didnt have the correct plugs. Any ideas as i have double checked the wiring.
sorry robo im a bit confused. i dont know for a fact the avcr map sensor is the same, it should be. can u give me the denso part number from it. the map sensor should attach to the 3 pin harness. the boost solenoid should attach to your stock wiriing. when you goto setting, boost what option is highlited and whats it set to ?
heres one for ya, my battery went dead flat and car sat there for 2 weeks, i jump started the car from a charger/starter pack and now engine light is always on and car stutters while cruising every couple of seconds. We went to a local tunig shop and they had a customers car with brand new power fc and we used that commander as i dont have one for mine. It plugged in and just came up with the apexi logo and thats all it would do. Are the commanders only suited to that specific ecu of should it have worked? Also any ideas on wether something has been reset or blown due to the flat battery then jump start? driving hard it seems to run fine with no stuttering but its when you sit on a constant cruising speed and also does it worse under less load. also after working on it tonight the voltage off the battery is at 14.8-15.5 volts whilst running and the battery light is now on!!
Bet ya this stumps ya!! lol
Edited by DRIFTPIG
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
