Hi
can someone advice me how to restart apexi fc??? i have tryed to unplug batterys but there is no changes... please help me
hi
its covered in the powerfc faq but to reset it ;
ETC, DATA INIT, choose YES, press NEXT
power the car off
next time you power the car back on perform the self idle learn procedure (also in the powerfc faq under install)
hi driftmiester,
no it wont, its just normal detonation occuring
follow the standard guidelines in the powerfc faq on how to debug knocking
no the z32 afm just allows for more tuning resolution and nothnig else, its the same size as the standard rb25 AFM so it wont add power
Thanks heaps Paul. You hv been a great help.
Im now saving up a Datalogit & probably a wideband, this way i will be able see more stuff with the laptop. Currently using the Apexi Turbo timer which also shows the A/F ratio but not very accurate.
Just wondering, did apexi make power fc's for automatic skylines?
no there isnt an auto skyline version of the powerfc
there is for toyota however as lots of toyota's are auto and i guess the code/logic is maybe a bit easier
hey paul, i just recently had a PFC + HC intstalled and tuned on my RB25DET, it was ok for the first week, but now im getting knocking anywhere from 80 to 130 when i plant it.. the weather has got warmer, and at night time i dont get much knocking at all if any.. is there any way i can fix this?
cheers..
Edited by EVL-R33
cheers..
hi,
just read the faq, its covered numerous times
look under technical issues
Hi Paul
Just checking whether under the SETTING for AIRFLOW, does the Power Intake refer to those ER34 who has changed to after market filter cone type? A friend of mine read it somewhere in the Japanese version manual indicated this. Just want to double confirm.
Hi Paul
yes you can choose the power intake when you change the airfilter but its not required
and it probably wont make any difference, i dont know any one thats done it and gained anything
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
