yes the only way, if you cant start the powerfc, or have it running in the car is the sticker on the powerfc case
if this sticker is removed, you have no way to work out what version, other than with a working hand controller connected to it and viewing etc, version
you can read here
http://www.paulr33.com/powerfc-faq/powerfc-faq.htm#70
but in summary
there are two mainstream powerfc versions
the first gen was sold without the hand controller and the model # is the car's engine model
ie RB26D or RB25 or RB20 so on the side of the powerfc case it has a serial number like RB25-201022 etc etc or RB26-232221
the second gen was sold with hand controller in a bundle and the model # is the car's model
ie ECR33 or BCNR33 so on the side of the powerfc case it has serial number like BCNR33L-4232123 or BNR34L-2321144
The L stands for L jetro ie, airflow meter and D stands for Djetro - ie BNR34D-21211 is R34 GTR djetro
now the hand controllers come in 3 batches usually known as FCC, FCC2/3 and then FCC EL (aka FCC4)
FCC EL or FCC4 works on every powerfc regardless
FCC only works on first gen powerfc
FCC2/3 works on first gen and second gen powerfc
My ecr33 power fc never had a controller so I got the new el hand controller. When I plugged it in to my ecu it says apexi and then says communication error. I checked it on my mates rb25 r33 power fc and it works fine. What's wrong with my power fc and where can I get it fixed in Perth? Help
yeah that is odd
it should work as the EL controller works on every powerfc except chaser auto
can you show me a pic of ETC, VERSION on your powerfc if you have another working hand controller?
if you dont can you look at what the version string is on the side of the powerfc case? it should a white sticker with ECR33-XXXXXX or RB25-XXXXXX
  • 4 weeks later...
Having a bit of an idle issue at the moment. I know what its doing I just cant work out why....
Ok, so engine is warm etc so it should be in normal idle mode, its hunting quite a bit. The cells its hitting on the map are all at 15degrees, but the hand controller is showing me that its jumping between 20 degrees and 15 degrees (may hit 19 or 18, but around 20 anyway)
So all the cells are saying 15 degrees, so is there something going on where the car is switching back and forth between normal and cold start operation? Not sure why else it would be jumping up and down. Appears worse when the A/C is on
Idle is about 800rpm, was around 750rpm last week and I upped the idle figures to get it to the 800rpm. It was previously 850ish rpm so not sure why its dropped (about a month or so ago)
So is it possible that I have something wrong with the cold start valve/temp sensor that is playing with the timing?
what have you got the idle values set to and what does it idle at when its at 15 degrees? the pfc goes into a closed loop idle mode and ignores the main ignition map, using between 10 and 20 degrees of timing to make it idle at the target idle, although it seams to do a pretty shit job of it sometimes.
My car wont start with the first hit of the key when its cold, I have to let it turn over a couple of times then let the key go and hit it again and it starts, is there any easy way to fix this, has to go back for a tune so im not overly worried but if I can fix it I will.
yeah it seems to hit 20 when it goes below 800rpm, but my boost gauge is showing im only gettting -10 vac instead of -15 that i used to get. I played with the tune a bit and got it to idle nicer now (the fuel cells it was cycling between were a fair bit apart) also upped the idle values to 900ish rpm (which you cant do on the HC but apparently can with FC-Edit) so it'll do for now (now idles around 850rpm). But I think I have a vac leak somewhere. Just cant seem to see where at the moment. will have to buy some spray to find it.
Thanks for that anyway, useful to know :)
target idle is under rev/idle in the settings menu of the hand controller. one setting for a/c off and one setting for a/c on.
normally a vac leak will raise the idle unless its huge. but if your getting less vacuum then its definately worth looking for.
what sort of afr are you getting at idle? RBs tend to need to be fairly rich to idle nicely, they usually miss and carry on if you try and tune it to 14:1 or leaner.
what are your cranking injector opening times set to? and what injectors are you running? sounds like its not getting enough fuel
Yeah I had adjusted them on there to 850 and didnt seem to help, cleaned the AAC and couldnt get idle to change by adjusting it (with TPS unplugged)
Went into FC-Edit and thought I'd just try and stab in a random number and tried 1000 and it accepted it so i just went down from there
My AFR's at idle are pretty lean, in the 16's but they've always been around there from what I can remember. It's O.K now, still isn't 100% but is alot better then what it was. Might try running it richer and see what that does.
i have no idea on the opening times, im running hi flow standards @ around 500cc, its odd that th first time you hit the key it wont start but the second time it starts perfectly.
in the settings menu of the hand controller its under cranking. does it sound like its not getting enough fuel or too much?
  • 1 month later...
Just wonder what everyone's values are for the exhaust gas senor, cold and hot on a R33 GTST S ii
I did a search for EXTM, Power FC exhaust senor but got squat on the value, did find a few cars for sale though lol :)
anyway
on the hand controller for the Power FC
Etc > sensor check > EXTM
Mine is stuck on 4.98 to 5, is stays the same, checkedbefore I start the car (when it was cold) and after driving for 20 minutes.
I got a new cat put on a few weeks ago, now have some strange things going on, car seams more fumey then normal. When I picked thecar they guy said the senor didn't fit into the new cat so he wait for it…. Welded the sensor in!
I never checked the value before the new cat went in but with my limited knowledge I am taking a stab in the dark that as the exhaust heats up this value should change to help control the mixture or something like that.
Cheers for any help you guys can provide
Edited by pfcr33
EXTM always shows 5 its cos the powerfc doesnt use it or from memory its always unplugged on ERC33
i wouldnt bother with it, its the cat overtemp sensor light on the dash
its probably unplugged on most gtst's
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
