  • Replies 630
get up
get on up
get up
get on up
and DANCE
;)-:D|-:D/-<
Xzibit baby
And the Bash.org quotes start to reappear
"I'll become rich and famous when i invent a device that allows you to stab people in the face over the internet"
hey guys and gals,
Imma wondering again if anyone from the northside wants a passenger tonight can you give me a buzz on 0423033902,
I still dont have my line but shouldnt be too much longer, but would love to meet a few of you.
Thanks,
Nathan
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
