The biggest issue i've been told that i will have with licencing this R32 is having an engine swap and v-mount cooler.
Anyone been through something similar? Offer me any info?
**Edit - Compliance and Engineers signoff done!!! This should mean no dramas about the 2 issues mentioned above from the pits.
  • 2 months later...
Just a little update...if anyone cares.
Engineers certificate a.o.k!
Went to the pits last monday and i think i got off quite lightly!
The bonnet is raised slightly, needs to be level with side pans, vents/pin holes need to be covered up.
I have to take the mech diff out...i thought i might be lucky and it wouldnt clunk when he test drove it, i was wrong :P
And I have to remove the hicas lock bar.
Almost licenced this baby! yay!
hmm.. i have a hicas lock bar and a raised bonnet too... i also have bonnet pins..
you had to change all that just for complience on an 89 model car?????
my car is currently being complied... like always i expoect the invoice to be much more then the quote i was givin :P
they are lot stricter over there, it has to go through a full inspection at the transport place before it can hit the road..
here they barely even look under the bonnet.
Compliance is all done. it wasnt done by a workshop, rather a highly recommended gent. I paid for the major stuff that i couldnt do (side intrusion bars, fuel neck restrictor, engineers signoff, child restraints etc) and chose to do the rest of the work myself.
good to see you got it all signed off!
when does it go to pits now?
good luck with it all
cheers
Adam
*takes a deep breath*
PASSED PITS TODAY!!!!!!!!!!
2nd inspection and not everything from first inspection was rectified.
Got permit for vmount, strut braces, carbon fibre bonnet etc!!!
Oh what a lovely day ;)
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
