well I'm just back and it was a great day not many car cause its overcast calder looked after us really well we started from the other side and got as many runs as you needed.
times
meggala best time 14.04 @ 99.86 with a 2.1 60' time
the ice gtr ( lewahs 11.50)
ex- static 13.90 @ 104
i nark 15.05
ait 15:.5
acsplit (16.5 ) not sure
post your times here guys
https://www.sau.com.au/forums/topic/6485-calder-results/
  • Replies 89
15.04 ET @ 92.66, 60ft 2.3
15.06 ET @ 93.3, 60ft 2.399
15.09 ET @ 94.22, 60ft 2.48
15.47 ET @ 93.01, 60ft 2.68
Dont know what the last one was...
none of them with a decent launch and the last one was even worse as u can see by the time.
took a while for me even to get a run as my line wouldnt even &$&$ing start... all dressed up and nowhere to go... so once we crashed started it i left it on for the whoel 3 - 4hrs i was there... engine was hotter than hell.
the calder team pissed me off big time after all the stop starts as we were meant to be next on the last run in which i would have got another 3 runs in (after the rain) but they let all the bloody V8s go who had already done 2 bursts before the rain... so in the end i only got to do one more without trying to get a decent R/T.
meh im still happy with the result all things considering (all things being heat, car probs and shit tyres). still kind of annoyed not making it into the 14s thanks to my launches... funny thing was that on the way home i would wait for the green and actually launch properly :cool:
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96820
^#^%$ nah i would have but i only had 3 hrs sleep the night before and had not eaten anything that whole day... plus my clock said it was 4pm lol so i thougt i better head in and call into work to tell them i wasnt coming...
meggala... i dont have the bigger turbo on it yet.... danny is going to sell me his dirt cheap when he puts his new one on it... or do u mean on urs?
all ive done so far....
POD
ECU
Stock boost.
thats it.
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96916
Hey Guys ..
The rain was annoying!! I didn't get to meet all of you guys, but none the less I had a great time.
I didn't get the chance to run the R33, so instead I took the Rexxie! (Dark Blue one)
My times:
First Run 13.62 @ 98.82MPH, 1.904 60FT
Second Run 13.74 @ 98.00MPH, 1.939 60FT
Third Run 13.72 @ 97.75MPH, 1.913 60FT
Fourth Run 14.84 @ 98.23MPH, 2.491 60 FT (missed 2nd gear)
Best Run 13.02 @ 101MPH, 1.890 60 FT **WOOHOO**
I would have loved to have run more boost (14 psi max, at one stage I was getting 10 psi in third ) :D
How loud was the car without the exhaust ??? But I think I lost a bit of mid-range because of it, but was all fun !!!!
Hope to see you guys at the next meet.
Eric
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96968
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
