Hi all,
I am planning to purchase a new head unit to replace my stock cd player in my R32 nissan skyline gts-t. I was just wondering how hard is it to install a aftermarket head unit on the r32? I have installed head units before on other cars but since this is an import i guess it may be a bit harder. Do you suggest i get it done professionally?
If anyone has done it before can they help me out or maybe even take me throught the step by step process. Also are there any special equipment I need to purchase prior to installation? Ive read on the R33 installation it requires an adaptor, what is this for and why?
Cheers
https://www.sau.com.au/forums/topic/65864-stereo-installation-in-an-r32/
installation in my R32 was straight forward just like any other car
only difference was the antena cable it has two pins rather then the usual single pin
you can get adapters for em but in not sure where
ok thanks for that, i feel a bit more confident now installing it myself rather than going to a professional and gettin ripped off.
about the adaptors, this would be the first time for me to deal with these thingys. Do they just plug in together from unit to cables and are they necessary? sorry for asking 2 many q's its just that once i begin installing i dont want 2 wreck anything or find out i need something else.
cheers
The power is on a seperate plug with three wires, using a currenty tester you will work out which is acessory and which is power, the third, and left over wire is not earth, and if used so, head unit will work but fuse for rear tail lights and dash lights will blow (yes i found this out the hard way).
Moral:
Best to run a seperate earth wire.
To get it out is relatively easy, just pull the dash apard, mainly the surround of the stereo area and the two stero units are conected to each other on the same brackt and come out as a double din item. Very straight forward and plain easy to work out once you start pulling it all apart. MUCH!! easier than a R33.........but they get an easyier amplifier install.
  • Like 1
Hi dude, I just installed a head unit into my R32 yesterday. Assuming you know how to take the dash apart, you need:
Antenna Adaptor lead "Nissan Double Diversity" - $12.99 fm Autobahn
wire stripper/pliers
either:
screw connector (its a little white box with screw in terminals) - $3.99 fm Autobahn (though about 80c fm Jaycar) and a small screwdriver
OR
soldering iron
I used the screw connector box cause it's easier (IMO) than soldering inside the dash, and if you stuff up (ie. connect speakers around the wrong way) it's super easy to fix, and much tidier.
I recommend beg/borrow/steal a multimeter so you can confirm which wire is which, just in case your car is different to others.
If you go to an auto shop (autobahn, supercheap, coventries) you might find a Nissan->Pioneer or Nissan->Alpine plug adaptor. Prob a good idea to check first, cause you'll save having to strip wires and test things out. I wasn't so lucky and had to suss it out with a mate.
If you need more info, beam over a PM and I'll try and help with any q's you still have. Once you have all the bits, it's pretty straightforward and will take 2h(ish).
Mark
and geordie is spot on, run a separate earth. There is a decent earth when you screw into the gearshift (the oval gasket thing that holds the rubber boot down).
I made it alot easier for myself, as my whole stereo is running from an amp, all i really needed was power to run the Head unit and ran a RCA through to the amp and all the noise is taken care of from there.
Im amazed that no on has mentioned you may need to do an amp bypass. It may have already been done or it may not have a factory amp. To check, its a small round thing in the boot, screwed to the underside of the parcel tray
Good point.
I didn't think to mention it because I used a new amp for all the speakers.
I think there are 11 pins on the factory amp plug, 4 speaker inputs, 4 speaker outputs, power, earth and trigger. Use a test light or multimeter to find 12v, earth and trigger then just join the inputs to the outputs. I think speaker positive wires are solid color and negatives have a trace. Anyway it's not too hard to sort out.
GL
Do you get shitty reception if you only use 1 plug from the antenna. Cause my car came fram japan with a "fm expander" and only one of the pins goes into it. And with my new head unit (Alpine CDA-9826) i get crap reception.
I'm just halfway through transferring my old head unit into my current car..
The only problem is that I'm hardly getting any volume out of the speakers. Think they are stuffed (factory ones), or just play at low volume.... Is there any solution for this, other than new speakers? I tend to get that problem with any factory speakers and this deck until i put new ones in, and then it's all fine :D
Just cut off the aerial plug and put the new one.. seems to get reception ok. Haven't connected up the "aerial booster" wire at all - sure its required?
meh, it works i guess.. just sounds pissy..Anyhow, pretty much finished mine.
If you have a bunch of plugs in there (like mine), they'll probably be for the double DIN, amp, stacker, or whatever else was in there once upon a time.
The only one you'll need to really worry about will be the big flat one, which is like one plug seperated into two sections - one with 6 pins, the other with 4 (only 2 filled with pins).
Here is the wiring:
Blue/red - Illumination wire (12v on lights on). Most stereos this is not needed, but useful if you want to tap off for a boost gauge light or something :O
Blue (4 pin side) - 12v accessories (i think it's either that or 12v constant)
Yellow - 12v constant (or accessories, see above :D)
Brown - Front Right -ve
Black/Red (below the brown) - Front Left +ve
Blue (6 pin side) - Front Left -ve
Black/White - Front Left +ve
Black/Red (below yellow) - Antenna boost. Connect this to your antenna/amp control wire. After a bit of experimentation, this *does* in fact boost the amount of channels I could get, so a good idea connecting this up.
Lucky the person i bought it off had already replaced the factory ones with decent aftermarket ones....just gotta get the new head unit. But at the momment ive been having probs with the factory headunit, sometimes the volume is producing only low sound even tho its up and sometimes it just cuts out.
have to say that installing my alpine head unit into my R32 was the simplest install i have ever done.
www.installdr.com
has a wire matching guide for head units in general. but does not mention the dimmer wire which i belive is next to the ignition wire on the plug (1985-1994).
only annoying bit was shaping the trim of the headunit to suit the step up on the trim around the din slots in the dash. (just used a file and a very sharp knife to cut the plastic).
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
