From what i hear i think you will be a bit disappointed with the Falkens. Ppl seem to think thye are a street tyre compund with a semi tread patter, where as the Dunlops / Bridgestons / Yokohamas are a softer compound.
Falkens use to be cheap, but they did have a price hike a year or so ago. What price are they these days?
Perhaps Toyo or is Kuhmo that have a semi type tyre?
lol everyone bags the falkens but have never owned them themselves
if your camber is in order, then the Falken RT215s will bring a big smile to your face :D
They did to me in 245/45/17, have gone about 8000km on them, still heaps of meat left, and i have NEVER lost traction besides full throttle cornering/wet
whats your impression of the re540's that the saloon cars run Duncan?
Ive never used them but apparently they are similar to the dunlop formula r (excellent). they were replaced by the re55s which are the new bridgestone tyres.
And yes knore you are right, I've never used rt215s, but they clearly are not as soft a compound as the other r tyres
what price are the RE55's going for?
i was thinking of getting some of the second hand tyres from the saloon cars.. about $200 a set since they are the same size as my rims, gotta be better than the crappy tyres i have always used.
$200 every 2 months, the tyres should last that long.
I now own a set of RE55's.
Got them from Melbourne from the SAU Vic arrangement. It's $150 cheaper to buy them there and freight them here and my mate can fit them for me.
I'd love to look after the club sponsor but if club discount is $150 more than purchase elsewhere+freight then no can do.
And as for grip I'm smiling already and I don't even have them yet.
I bought 2 x Falken Azenis RT-215S's for the rear, about 2000km ago, i must say i'm very impressed with their grip levels. Only had them let go once, and that was severe provocation... i.e. 90 degree righthand corner, 1st gear, full throttle, up a hill. Even then they didn't let go in a big way, they still kept gripping, and pushing me fowards, where my old tyres would have just been a plume of smoke, with me not accelerating very fast at all.
Edit: P.S. They were 205/55/16's to fit onto standard R33 Rims, $255 each.
same.. I've installed a set on my 32 GTS-T and they're awesome road tyres. Through the mountains barely would lose the tail, even at quite silly speeds. And that is with a stock suspension setup. Will have to see how they go with a bit more power through them to adequately get an overall comparison.
We'll also see how they go on the track in about 2 weeks.
Whilst R compounds are great for the track, you really do want something that gives you more than 10,000km in general use.
You'll feel every bump of the road with the RT215's though.. and you'll also hear them quite a lot.. I dub them "stone throwers" ..
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
