  • Replies 121
Its just that game should be accurate, the powerful real wheel cars do produce wheel spin and can oversteer but the oversteer is not reflected to what happens in real life. You push the directional button hard left or right and floor it and the car will go in a complete circle will out breaking the tail out, to me that dulls the game and makes me think there is to much incorrect understeer programmed in every corner you attack.
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1245485
having the driving force pro helps with drifting as well, but seriously as everyone else said, it's all dependant on vehicle setup and your control of the vehicle.
it's not like the bull in NFSU with it's unrealistic crap drift.
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1245866
lol...yeah same as what duncan said.
"Mike9" when you say that high powered cars create wheelspin to generate oversteer?? do u mean just getting the tail out prior to corner entry??...thats more suspension/tyre setup than power i dont think thats really termed as oversteer, well from what i understand anyways....thats just plain old drifting:D
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1246425
The game is fantastic... so much fun 'drifting' my r32 gts-t around but is anyone else pissed off that EVERY other model is skyline is in this game (including about 10 different varieties of R34 GT-R) but yet there are no R33 GTS25t of R34 GT25t (except the D1 version)????
I mean it's just disappointing not being able to buy the car iown in real life and driving it :D
https://www.sau.com.au/forums/topic/66989-grand-turismo-4/#findComment-1247404
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
