  • Replies 63
Forget the others and go a STAGEA.
I too owned a Mazda Astina but gave it to the EX and brought the Stag and what a surprise. Get the series 2 with the Neo motor, I prefer cloth seats espeacially if you live in a hot area and some come with reclining back seats choice of colour is up to you and you won't worry about the volvo jokes after you leave them at the lights. Your biggest problem will be keeping the missus out of it as it can be a very versatile vehicle and if the kids are a problem you can fold down the back seats and Nissan do supply good tie down points if required.
Good Luck
Gary
id go the stagea, chaser, or tarago/odyssey, or one of the bigg VIP lexus sedans. depends on what ur after exactly.
magnas and camrys not much bigger than 4dr skylines and the like. commodores and fords are, but the quality is pathetic.
i owned a 2000 Liberty wagon, it was a great car, little lacking in the power though, it felt like the gbox was for a 2L not 2.5L. parts were a bit of a hassle and the gbox was very notchy, as they are.
cheers
Linton
Try a Forester GT, I have one as a daily practical car, its not too bad.... has heaps of load space and a gaint sunroof if you get the luxury pack!
In standard form they are a bit of a slug but can be made to perform ok with with some decent bolt-ons (3inch zorst/CAI/wrx TD04L turbo), handling is crap but it can be made better (wrx rear swaybar helped mine heaps) and at least it has plenty of grip. :(
Good luck! :)
maybe a r32, r33 sedan, if you wouldn't want to spend to much on an r34 sedan, or even a JZX90/JZX100 chaser/mk II sedan.
stagea is another good one but the RB25DET in it will have to pull more weight as compared to the weight in the r33 coupe. i have also read that almost all of the stageas are auto's (so u won't have the full potential or the RB25) also the auto trans is a bit laggy.
Jzx90 Mark2? one in the trading post for $19k. 5 speed and twin turbo. Stock I'd say there pretty slow.. With a few bolt on's you can have some fun. Mate has one with around the 230rwkw.. Very interesting in the wet to say the least.
ever driven one? My STOCK auto Jzx90 mark2 ran consecutive 14 flats..... add an exhaust and stuff and your looking mid to low 13s... for a large car weghing over 1500kg that's impressive.
that's pretty quick IMO...
sigma!
nah, a stagea would suit nicely. bit plain looking but the autech kit is delicious. a chaser would be good too, how bout a vip cima/q45/celcior ect?
get yourself a copy of hpi no 49, inside is a 4door import guide. what an cool wife
What I've been lookin at:
WRX's
EVO's
R34 Sedan
Stagea
And right up the top is a Mazda MPS but thats pushing the budget just a little well alot.
I'm looking at manuals would prefer it to be turbo.
EVO EVO EVOS!!
or maybe a wrx hatch i reckon these days they look much appealing than a sedan
EVO EVO EVOS!!
I agree with the WRX's if I end up with ne of them it will be a Hatch.
Stagea is looking like the one though :rofl:
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
