  • Replies 167
plenums like this do make alot of difference. me and my mate tested the difference between our cars, both stock rb25's, mine had custom plenum, same size turbo. mine would kick in at 2200 and hit 1 bar by 3500 and his would kick in at around 3500 and hit 1 bar by 4500 rpm. although his was running stock computer with a safc and i was running a microtech LT-16s, im sure that tuning didnt make that much of a difference.
You're kidding right. otherwise you wasted your money on the full ecu replecement. You could tune igntioin timing and he couldn't, and that the biggest single factor in improving response. :D
for less than 1500AUD i got a very well made intake mani by RIPS in NZ, as for power #'s ive no idea as my engine is still sitting on the stand awaiting cams to make use of the free flowing intake plenum and the hks exhaust mani i have now.
Even if the custom plenum doesnt give gains in horsepower which is debatable there would still be sustantial gains in throttle response in the form of reduced throttle lag am I correct.
Nope, the throttle butterfly on a front fed plenum is further away from #6 and #5 than standard.
And wouldnt the shorter pipes improve inlet temps thus horsepower?
Again nope, it's simple mathematics the air travels though the pipework so fast is hasn't time (or sufficient contact area ) to pick up any temperature. The numbers look like this;
5,000 rpm X 2.5 litres / 2 (its a 4 stroke) X 2 (1 bar boost) = 208 litres per second.
:D
Nope' date=' the throttle butterfly on a front fed plenum is further away from #6 and #5 than standard.
And wouldnt the shorter pipes improve inlet temps thus horsepower?/QUOTE]
:D
So basically what your trying to say is using the standard throttle body and plenum is just as good as if not more efficient than a front fed plenum?
you'd think that whoever the owner of the car was would be better off spending the $1500 on a powerfc and tune if they're still running the stock computer.
And if it already had a Power FC, I would vote for a split dump and hi flow cat. Then a decent clutch to hold the power, then a set of injectors, closely followed by a fuel pump to supply them. Then a pair of Tomei Poncams, a turbo, exhaust manifold etc etc
It has been my experience that all of these would give a more substantial power gain than changing a plenum.
Don't get me wrong, a plenum upgrade would be on my list and the UAS one looks very nice, but it sure as hell would be a long way down my list:cheers:
Boosted zed with the manifolds are you polishing the inside of the chamber and trumpets? As ive been taught that you need a rough surface to help atomization of fuel and air mixture! If there polished to much it wont work to its full capabiltiles!!
Perhaps John did this to a car with a stock computer and exhaust to show what his plenum can do. It looks more like an exercise for demonstration rather than a "hey do this mod first" thing.
I'm sure he is going to post a before and after Dynograph for us to ogle. If he hasn't got them already it would be worth his while to do so if it proves him right.
John has aready posted the "after" dyno graph.
It was done on Wednesday 3rd November last year.
Ambient temperatuer was 22 degrees so it was a cool day for November
Boost was 12.6 psi max, dropping to 10.5 psi at 6,900 rpm.
John mentioned that it had a "standard dump and engine pipe", to me that means it had a hi flow cat and a cat back exhaust. Must have been a good one to be producing increasing power over 6,200 rpm.
John's post is a little confusing to me, but since he mentions "end tanks" and "USA core", I assume the car had the UAS intercooler and pipework as well.
So the only thing that stands out to me is the "standard ECU", I would never be able to get a "standard ECU" R33GTST to 208 rwkw. The ECU would go rich and retard (based on the AFM voltage) long before I could get to 185 rwkw, let alone 208 rwkw.
anyway, dyno graphs? am i invisible?
* UAS RB25 Plenum & Intercooler
* 12 Psi
* Standard ECU
* Standard Turbocharger
* Cat Back Exhaust
* Pod Filter
I doubt a PowerFC and tune can yield as much gain with just a cat back and pod...
* Why design the unit as a bolt on top half (rather than welded to the lower half of the runners ala RIPS style)?
I've got two issues with the two piece design. First, maintaining a nice flat surface to get good gasket sealing is more of a problem (ok, machining will solve this, but you don't need to worry about this with a one piece design). Second, you introduce potential for air leaks around the bolts holding the two halves together (which can be avoided using blind holes or lots of thread sealant - but once again not a concern with the one piece design).
* Is the end offset to accomodate the clutch cylinder on Rb20's?
* Does the plenum accept all std sensors and actuators?
The only way that car could possibly produce those kind of figures are,
#1 if it was running C16 which would give high hp increase.
#2 the dyno is reading wrong. - "Air intake temp sensor"
#3 The base timming has been advanced well past 15* BTDC
And, Stock Dump Pipes would be creating that much back pressure, The turbo would be chocking on its self.
guys let the argument go.
John has posted to let everyone here know of his new product and the results they got. if u doubt it y dont u go see him urself or pm him. im sure when he gets time he will post up all the details of the car.
http://www.skylinesaustralia.com/forums/at...achmentid=25735
This car has:
209.5kW 96 Series 2
Engine management - Stock ECU
Boost ran - 12psi
Turbo - HKS 2540
Fuel used - BP Ultimate
Stock all other internals.
Blitz DSBC 1st gen
Hybrid Front Mount
3" Exhuast from turbo back
Pod Filter
Stock BOV
  This car has:
  209.5kW 96 Series 2
  Boost ran - 12psi
  Turbo - HKS 2540
  Blitz DSBC 1st gen
  Hybrid Front Mount
  Pod Filter
  Stock BOV
Yes all nice, with a HKS turbo. But the car of intrest is:
SKYLINE R33 GTS-T
12 Psi
Standard ECU
Cat Back Exhaust - Stock Dump Pipes
Pod Filter
208.4 KW AT THE REAR WHEELS
From UAS web page.
He he - I knew this would happen.
John - get my old car. Do a dyno run before (with the Greddy plenum). Then take the Greddy plenum off - Put the UAS one on , with the polishes bottom runners and then put it on the dyno again - then post the dyno graphs of before and after.
I am not saying one is better or worse then the other - just a comparison.
I don't the answer - but I do know that from looking at a front facing plenum and the flow direction, it seems to ME that they make better sense than the standard ones. The standard ones to me shoot air directly into ports 3 & 4 - But as SK says he doesn't see this with his analysis.
Keep up the good work.
Cheers,
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
