Mate of mine put an new turck turbo on a GSR, didnt boost in 1st, started to boost by about 7,000rpm in second and mate about 185awkw, which lasted for about 2 weeks before it blew.
He now has a turbo suited to the motor and goes about 10 times better...
i personally wouldnt go near a truck turbo...
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1300459
rofl truck turbos don't work? Of course they do...there are plenty of people running TD06 on these forums.  In fact Roy has one on his rb20
Little bit different tho isnt that Duncan??? Im not trying to be smart either, I just thought his would have been as any of the TD range on cars would have been changed to suit cars not trucks, even if their orginal reason of life was for trucks.
Anyway I still say they are turbos for low RPM work, and need big mofo engines to get them to work how they were designed to. And after you have to get manifolds etc made up, its probably cheaper buying a 2nd hand bolt on.
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1300464
yeah don't worry about me, I'm just being a smart arse :) There are plenty of good, cheap car turbos out there, I don't see why you would bother with one not designed for a car.
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1300477
Turbos are pretty much banded by CFM so if the volume of air going into an RB20 is XX amount to make the power you want and the velocity/volume of gas coming out is sufficiently matched to the turbo and the rev range you want power then it will work.
Now whether it will be laggy or give good response due to the construction is a different matter. Being off a truck it will probably need a large volume of flow to be happy, as truck engines tend to be large capacity long stroke slow revving things with the deisels have especially high compression ratios for compression ignition (no spark plugs). Also, being off a truck the rotating components may be of sturdy construction as response is not as important as longevity. May not be the case but something to think about.
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1300498
  • 3 weeks later...
Truck turbos ule:thubsup:
I have a sneaking sus[icfion that a Cummins turbo will be too big...lol... sure would look tuff though:)
See HPI / Mart8in Donnon could only get 210rwks out of a TD06 on an RB20:(
And momentarily, until I looked at the time stamp, I thought "What alcohol soaked hour of the evening was this typed?" But it looks like he's just off to work LOL
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1326597
yeah, but didn't the owner just want to stop at 200rwkw and not push it further for durability reasons?
so the boost was only 15psi just enough to get it into its efficiency range.
it doesn't say whether its a 10cm or 8cm housing like yours Roy?
:headspin:
https://www.sau.com.au/forums/topic/70370-truck-turbo/#findComment-1326599
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
