  • Replies 43
I get the stutter when low boosting, but i was really after the high pitch ching sound. Do you need to run more than 7 psi to get it?
Apexi dual chamber BOV is easy to install and sounds awesome, has that high pitch sound when revving hard!! also has 3 different sounds but you can hardly notice the difference between them
i don't know if i'm sold on the brotec. my cousins friend had one on his 180 and it didn't make the whup-whup-da-doo-whup-chufff sound he wanted. maybe he just didn't have the right setting chosed on his ecu? the brotec bov is tuneable, isn't it?
Bro you gotta retune it, I know this guy with a whikid hookup at Carshop nagano if it helps.
They offer a complimentary can of coke while you wait to
Why would you bother getting an aftermarket BOV that is plumb back if the stock one is plumb back ?
So basically atmo BOV's are good for performance because there is a slight decrease in lag and they prolong turbo life but plumb backs are good because they give a smoother ride ?
i would love to go, but eddy told me they want 3 surfie shirts per re-tune?? I don't have that kind of doh atm... ;)
almost right.
the only change to your post is that ATMO bovs are good for nothing.
Aftermarket plumback bovs are good for the sticker they come with.
This brotec device sounds interesting.
I'll take 12
almost right.
I'll take 12
As a matter of fact Brotec is running a special, buy 12 get 15 free, but the offer is strictly limited to the next 50,000 callers - be quick
almost right.
I'll take 12
i will sell you mine. I'm sick of the farking thing. I've had to have it re-tuned so many times it's not funny and it still doesn't go whup-whup-da-doo-whup-chufff.
I got a HKS super sequential BOV on my car....only because I don't want my turbo stalling when I lift off the throttle. I dont care what anyone says, I'd rather be safe and run a BOV cause for me a GT30 aint cheap. Anyways, I must make my point about the HKS superquential BOV: what a gay souonding BOV. WTF did the designers think: that a squeek is a nice sound....they gayest sounding BOV on the market. The design concept it great but why did they choose that sound? Im gonna plumb it back very soon. If anyone knows how to make it sound just like a pssssht rather than like a cat getting run over, let me know. The reason why I bought this valve is because of its design (push-pull) which garantees no leak but sure as hell not for the sound.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
