FAQ: Can I use PVC pipe for intercooler piping
  • Replies 60
  elbee111 said:
Use the bends and that is exactly what it is eh !   :crazy:
Enjoy   :)
I'm sure all the plumber go via Liverpool Exhaust before they fix a dunny.
..even though I'm taking the piss, I'd love to see this done :Pimp2:
autospeed.com.au did an article a few weeks back but instead of pvc pipe, they used copper pipe that slips together and you braze/solder it.
apparently before it all went pvc, copper was mainly used and is still available from good plumbing stores.
i was suprised at how cheap the article claimed that the copper pipe was too.
worth checking out.
i used a bit of pvc on my old 1.6 turbo tx3 when the cooler hose popped. it melted after a few mins cause it was too close the exhuast manfold. so i assume if you make cooler pipiing out of pvc, youll have to wrap it up to stop it fom being cooked.
steve
its can be done but i cant imagine myslef with a bbq gas bottle and a stupid gas pipe with metal tip spitting flames out of it.
if any1 have a safer way, tell me i wouldnt mind trying it out myslef.
on secound thoughts..............i think its too dangerous, ill let nj hurt himslef first b4 i try it out. relise heating it wil making it more brittle, prone to break or strecth, so any high pressure going through wouldnt be too safe.
:S all my support lies in NJ
worth checking out.
The hybrid kits come with copper piping
I gave the electrical piping a look and found it softens and deforms at 98 deg C, which is no good for the sustained high temps in the racecar.
Good concept but just no longevity.
I saw some PVC intercooler plumbing on a CA18DET S13 Silvia runs 13PSI. He painted it black. It doesnt look bad. To be honest I probably wouldnt have even noticed it if he didnt point it out. Seems to be effective. Although I personally wouldnt do it because I can get SS done relativly cheap cause my mates are boilermakers. I cant see anything wrong with PVC.
ya, the high pressure stuff is generally green :P
i dont think id trust pvc pipe as I/C piping.. the middle is a foamy-like substance, its designed to run on a 2/3 full system, so its never actually full, or under pressure, whereas 'pressure pipe' is designed for a full, pressured system, but at 2-3" isnt alot cheaper than steel, if at all..
ill just buy some s/s pipe from work at wholesale price for mine :rofl:
I'd like to see it do 10 laps of a race track. OK for a dyno queen or daily driver where little time on boost is seen, but on a track the heat will have time to soak and then you have a problem.
