  • Replies 77
']The ceffy doesnt have a bov
it has an external venting wastegate. sure its not legal but its set up like that for track use. it sounds nothing like a bov or flutter ffs
It was hardly on boost, we (people around Mikey's car) heard it as it was leaving the complex...
hardly on boost = lies
its needs to be on or close to full boost for the gate to open or it doesnt work.
Adrian... my honest opinion is absolute shit all... not due to sau but due to the way the event was organised by cabin in some areas, ill be emailing jason fro andra this week and il pm you a copy
']hardly on boost  = lies
Im with you on this tj, the event wasnt organised very well, Get to the gates at dead on 12 and they hadnt open yet, had to wait for a good 15 to 20mines then there was ahold up took about another 20-30mins to get inside, *i heard that some clubs money didnt go through and they had to pay again i belived this inc sauwa*
anywayz i get to the gate tell the person who i am, and she just give me tickets and sends me off, unlike last yr were they gave u a map and told u where each car club was, this yr i had no idea where anyone was. i couldnt find antilag so i was force to park my car else where and i only found sauwa cuz i look where the RH9 GTR was.
Also there was no supercruise :) that was something which i really like about dc last yr, too bad it wasnt there this year.
I think last year it was run much better, didnt like the classes that much but hay it can only get better from here :)
I think overall the event was bigger and better, but I agree there is alot to still improve on, including club setups, speed of entry and scrutineering. I get to see things from the organisers point of view, and trust me we're working our asses off, but with better organisation things would have been much better.
Please feel free to provide me or TJ some feedback, and then we can pass it on to the organisers to make sure next year is even better.
Cheers
Paul
Yes it did Glen proving HP means very little.Steve Lee puts together a mighty engine so i cant wait to see this GTS on drag rubber.
The one thing ive seen working with trev cars is how little it takes to run fast like the white L34 Torana(Full street trim etc) at last fast friday, ran 10.9 on treaded tyres with 383rwhp but was over a very broad band.
The Hyperdrive 180SX that competed at Combat has been tickled and put-down 477.7hp at the treads this morning. Shame we didnt get time to do that before combat as I am sure it would have slipped into the 10's for sure. It was a mission and a half getting the RB25 box in there - didnt even know if that was going to work out until the night before!
The point I am getting to is that in terms of 'RESPECT' here comes another Jap Rice Rocket that can idle in traffic and throw a 10sec 1/4 down. They will start learning there's more to life than pushrods!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
