Hey Fellas,
I've been creeping round while waiting for my line to arrive and hopefully it arrives real soon! If it gets on this months ship then it should be here on the 12th. Below are the pics of my baby. It's a bit dirty but a good amount of elbow grease should get it looking scmick!.
What do you guys reckon?
Also I've noticed taht in the engine bay near the back I have only 2 cables instead or the usual 4 of 5 that normal GTR's have? what are those cables and am i missing somthing? In the GTST's they have only 2 cables at the back so hopefully it's not a GTST --> GTR conversion. I think i'm being paranoid but you never know. Someone please enlighten me.
https://www.sau.com.au/forums/topic/72079-another-32-gtr-or-is-it/
yes they do..
Either this car chose no ABS option or was removed
I thought it was standard equipment but i guess not.
looks nice but :D
Thanks! with the engine how much would it cost to get someone to professionaly detail the bay? I would do it myself but i'm afraid of breaking somthing. :Oops:
12 more days :) heheh
nOOSE
Is it a NISMO Edition GTR? I know the NISMO ones came with no rear wiper and some other slight differences, maybe they also had no ABS - because I don't think something that aids drivers would be allowed under racing rules.
*edit*
Actually yes, I'm sure that's it.
Here's 2 of them on Prestigemotorsport, they only have the 2 wires you mentioned. Compare them to "normal" R32 GTRs that have the 5.
Nismo 1
Nismo 2
*edit*
http://www.prestigemotorsport.com.au/au/stock/details.asp?StockID=2754]Nismo 1://http://www.prestigemotorsport.com.a...ID=2754]Nismo 1
Nismo 2
So i've got the NISMO GTR.! that sounds pretty kewl. Time to search and find out the differences.
Hey Guys,
I can't find any decent information on what are the differences between nismo and non nismo. Some say no stereo, no A/C and others say it does and blah blah. Tried googling for the past 3 hours at work no luck all speculation. Does anyone actually have an idea what the differences are? Here's a few more pictures of the car if it helps to distinguish if it's a nismo.
nOOSE
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
