May Monthly Dinner - 26/5/2005 - The Great Northern - Pacific Hwy Chatswood
  • Replies 222
I had fun Richard:cheers:
I am in (so long as the baby has arrived) and I am not fussed on the venue.
The Willoughby Hotel was a good feed, so may be someone can suggest a place like that with variety, it does not have to be a restaraunt.
Suggestions ?
Roy, if you are keen for some bbq or pub beers one night give me a shout mate. I live in chatswood. keen to check out your car and meet up.
carlo, CYO could be good. The Great Northern does it too.
Be good to get away from these mentally defective Victorian folk. Working in Chatswood so anywhere up that way will be good
Buddy... what are you saying. Mental... Yes - Defective... not in VIC
Are you based in NSW now for good or the next few months/years?
Victoria's response to Troys slagging http://www.skylinesaustralia.com/forums/sh...ead.php?t=72464
:spcow:
Hopefully I can make this... Last month was a shocker, so hopefully I won't be as busy this time 'round!
Oh, and when I go out to eat, I'd prefer someone else cook my food for me :cheers:
How about Bella Mia? this is a great restaurant in Roseville. it's italian food and very, very good. it's high end though so not pizza, spag bol etc. more like carpaccio di manzo, and scalopine di vitello con funghi (two of my favourites). mmm i can taste it now. or the northern is quite good, plus for andrew they will cook for you. people who are so inclined can cook their own.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
